+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 17
Thread: High temp silver discoloring
  1. High temp silver discoloring
    I am having problems with the Caswell High temp silver discoloring after it heats up. I used two coats and baked according to directions. This is for a major client, and I need to resolve it quickly.
    Please HELP! This is after only one flight (about 15 minutes)
    Share with Facebook
  2. Join Date
    Dec 2002
    Location
    Central New York
    Posts
    353
    My first thought from looking at the pictures is how much was it handled?
    It looks like oil from hands burning on the coating.In the photos some spots actually look like finger prints.You may need to run some shorter runs at first to season the coating. This will act as a higher temp baking.
    Share with Facebook
  3. How can I prevent the oil from burning on the pipe? As with any engine application, there is going to be oil present. Is there some kind of clear coat available to apply? There has to be a solution to this as this powder is made for headers and hot engine parts.
    Share with Facebook
  4. Join Date
    Dec 2002
    Location
    Central New York
    Posts
    353
    What did you do to prep it? Was this muffler new?
    Share with Facebook
  5. It was chrome, but was stripped and sandblasted prior to coating. The chrome plating on this pipe was flaking, and the manufacturer wanted a solution. The chrom and other plating was completely removed and the aluminum was bead blasted to a shiny finish.
    Share with Facebook
  6. Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    315
    Did you Prebake it after sandblasting? I know that I have to do that or my powder looks like dodo! I have some Valve covers that I have blasted and prebaked 2 times already and I plan on prebaking/outgassing at least one more time.
    Share with Facebook
  7. I was under the impression that outgassing is not a problem with aluminum. I didn't prebake, and the coating looked great when it was finished, it was only after using the muffler that it started discoloring. The finish still looks solid, it's just ugly now that it's coloring
    Share with Facebook
  8. customandsound Guest
    after you out gas clean it again . and the oil from your fingers will show if not cleaned off . i wear rubber toss away gloves when handling all part's ... from what i found about alum. it has alot of little pores and the mixture is not the best on some part's .. the usa part's and coarse and the jap part's are nice to work on
    Share with Facebook
  9. The pipe was clean as in the pics even after baking, if the discoloration is from oil, then it came after the final bake while installing and using. The part is going to get dirty during use, and if it's that oil burning there is no way around it. This stuff in person looks like the actual powder is discoloring when you look at it, almost like it's rusting.
    Share with Facebook
  10. customandsound Guest
    if it is powder form caswell contact them ... you may need to use tech line of it i know them little motors let out some heat ...
    Share with Facebook
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Thread Information
Users Browsing this Thread
  1. high temp sheeting
    By craigcraig in forum Powder Coating Questions
    Last Post: 08-09-2004, 12:15 AM
  2. High temp silver discoloring
    By sgunn911 in forum Powder Coating Questions
    Last Post: 07-26-2004, 06:52 PM
  3. any experience w/ high temp on headers
    By RossL in forum Powder Coating Questions
    Last Post: 05-05-2004, 08:11 PM
  4. Can I use VHT high Temp with Krylon High temp radiator paint
    By magnus in forum Other Metal Finishing Questions
    Last Post: 05-03-2003, 11:20 AM
  5. High quality silver plating needed.
    By clovenguth in forum Services Offered/Wanted
    Last Post: 04-02-2003, 01:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
