Old 08-08-2004, 10:55 PM
customandsound
Guest
Posts: n/a
Default new oven in the work's
well it is time to either get a new one or build one ...
this oven is gas fired (propane )
now here is a question.
the body it 1/8 steel skins on the inside with alum. plate on the outside
what would you think would be the better barrier in the middle .. rock wool of that foil coated board ?
this is based on a bbq burner setup ....
i did a test on a smaller box i built and i got the box up to 500f with no problem ...
Old 08-08-2004, 11:07 PM
getastro's Avatar
getastro
I would think rock wool is the better way to go. I am looking into building a gas oven. The electric version kills the meter. Just looking into how many but’s are needed. Post pics when your done if you would.
Old 08-09-2004, 01:17 AM
WAORacing
Default Re: new oven in the work's
How big is the oven going to be?
Old 08-09-2004, 11:18 AM
customandsound
Guest
Posts: n/a
24" wide 4' higth 8' in lenght ..... just big enought to side a cycle frame in
i may have to go 36" wide
i also am building one 24 wide 24 deep 36 high ...
the electric prices are getting out of hand and i can get my tank's filled for 10 bucks each
Old 08-09-2004, 02:15 PM
remotestartdepot
What is rock wool? Also, where can you get rock wool and that foam board stuff you'te talking about?
Kris
Old 08-10-2004, 02:02 AM
customandsound
Guest
Posts: n/a
the foam board is the foil coat stuff and the rock wool all can be had at the local home improvement store.....
i seen a noob oven on a search that was buit out of foad board ... and yes it folded
Old 08-10-2004, 09:51 AM
Rock wool or mineral wool would be my insulator of choice. Rock wool comes in several "grades" or densities. A medium density should be plenty for building an oven. The other potential insulator I would consider is rigid fiberboard. It's cheap easy to get and can be stacked to increase it's efficiency. it comes in 1" and 2" thickness. I'm not sure about the rgid foam board. Even with the foil backing I would think it would break down very quickly and emit some pretty toxic fumes. I'm not sure if the foam board is made for that type of insulating. Perhaps a little research is in order.
  #8 (permalink)
Old 08-10-2004, 09:53 AM
Noob2PC's Avatar
Noob2PC
t
HEY WAS that comment pointed at ME?? hehehe I am getting ready to make something else for my operation that you all will love
  #9 (permalink)
Old 08-10-2004, 11:49 AM
customandsound
Guest
Posts: n/a
Originally Posted by Noob2PC
t
noob yes it was here is a link: http://www.pelicanbbs.com/posts/142071.htm
it is made from fiberboard ..... and it is his spray box to ... i see bad thing at this
the wall's on my oven i figure need to be atleast 3" on the sides 2"on the front and back and 3" on the top
but i may be wrong
  #10 (permalink)
Old 08-10-2004, 01:20 PM
Noob2PC's Avatar
Noob2PC
Cool, I wonder if the stuff you get a Home Depot/Lowes will withstand the heat or if he has a different product. Guess I can Try it and see if it goes POOF! You all would recommened at leat 2" thick.
Cooking up an oven project... dagobert Powder Coating Questions 33 06-09-2008 04:43 PM
advice on oven propane or electric RCC Powder Coating Questions 13 11-26-2006 10:57 PM
Oven problem !!!!! tavo1765 Powder Coating Questions 7 10-06-2005 06:21 PM
Newbie and oven temperature ? Netnut Powder Coating Questions 2 05-26-2005 10:49 PM
