FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 09-01-2004, 08:01 PM
Zinc Plating Guru
Default Combined powder coat & anodize
This is a dual forum post, involving powder coating & anodizing. I’ve posted this on the Anodizing forum as well. Now that I’ve got these two figured out, it’s time to do some real parts.
I’ve got a cast aluminum part that has a steel part embedded. I’m planning to mask the steel (w/Caswell liquid Mask-It), anodize the aluminum, then mask the aluminum, and powder coat the steel. (or the other way around).
Is powder coat affected by an anodize bath? (25% sulfuric acid)
If so, I can mask it off, but then is the PC surface finish affected by the masking agent?
Best to PC first, or anodize first?
Does anyone see other problems with this?
Thanks, Sean
Old 09-02-2004, 10:25 AM
Noob2PC's Avatar
Noob2PC
I would anodize first then powder coat. I dont think the PC would survive any kind of soaking.
Old 09-02-2004, 11:13 AM
customandsound
Guest
Posts: n/a
the acid will mess the the powder up .. now when you mask off the anodize you need to use a fiberglass tape or what not
Old 09-03-2004, 12:31 PM
Zinc Plating Guru
Thanks guys!
Concensus from both forums is to anodize first, then PC.
There’s a potential issue w/different thermal expansion rates between raw aluminum & the anodize layer, so I’ll have to test that out first. If so, I’ll reduce oven temp to recommended minumum & post the results.
powder coating over powder coat? corybarta Powder Coating Questions 6 08-21-2006 08:15 AM
Finding a place to powder coat RCLSolutions Powder Coating Questions 3 05-04-2005 09:42 PM
Laser printer = Powder Coat Printer? tbloss001 Powder Coating Questions 11 08-30-2004 06:08 PM
Magnesium-sticking powder coat to it and the cleaning proces fst951 Powder Coating Questions 5 04-14-2004 01:53 AM
Painting over a powder coat chromo Powder Coating Questions 1 01-29-2003 01:20 AM
