Old 09-20-2004, 09:14 AM
kecf
Default clear powdercoat over airbrushing?
just wondering if its possible to apply a clear powdercoat over an airbrushed design on a gas tank or will the heat from curing ruin the airbrush design?
Old 09-20-2004, 10:36 AM
customandsound
Guest
Posts: n/a
do a search there is a topic about this ..
Old 01-15-2005, 01:21 PM
VPC VPC is offline
VPC
Where is this thread?
I have searched using every combination and come up empty.
I also would like info on clear pc over airbrush work.
I have a friend that wants me to pc for a base then pc clear over his work.
Anybody out there have any exp. at this ? Thanks Steve
Old 01-15-2005, 07:30 PM
Do you already have the powdering equipment? If yes then have your friend paint a scrap test peice and see if it will take the heat.If the paint doesn't fail the heat test then powder it and check again. There are many chemistries of paint on the market so it is usually best to test with the actual materials you intend to use. With the test and see method you can insure that you are getting exactly what you want.
Old 01-15-2005, 11:28 PM
yes it works , I've done it few times not on complicated art though
you need to use high temp ceramic paint
the one used for porcelain ceramic crafts and that needs to be baked at 350 degress
YOU CAN"T GO HIGGER THAN 350
I cure the clear for 15 mins at 350 it's a bit under the recuired time for curing but It worked fine.
I used paint n' bake paint found it at a local craft store.
Old 01-16-2005, 10:01 AM
VPC VPC is offline
VPC
Thanks.....
I have some "House of Color" paints.I'll just have to dust off the airbrush and give it a try today.Ceramics won't do for this guy,he's stuck on the paint he uses.But I will try a low temp cure.
It's a solvent based paint so it should get a pretty good bite.
I understand I can go down to 300 degrees on a cure just double the cure time.......Is this about right?
Will clear powdercoat dull a polished finish? wozzwinkl Powder Coating Questions 3 09-22-2004 08:53 AM
Can you powdercoat over powdercoat? gopedhead Powder Coating Questions 1 12-14-2003 06:17 PM
Problems with clear, flowout, multiple colors, more... allcarfan Powder Coating Questions 3 08-25-2003 10:49 PM
Plating clear plastic Dinosaurius Electroplating Questions 2 06-11-2003 01:06 PM
Clear coating? Derrick Metal Polishing Questions 9 06-16-2002 11:34 PM
