| View Poll Results: Can You Cure PC on Caliper without damaging the seals | |||
| Yes |
4 | 40.00% |
| No |
6 | 60.00% |
| Voters: 10. You may not vote on this poll | |||
Here is what I did (It is a bit crooked)....Buy new ones from a place that will warranty for life, powder coat, cure get new ones and do the old swap-a-roo on the seals and pistons. That trick is a bit easier if you know someone at the auto parts store.
I just did my caliper this week...
Here is what I did.... Pulled bleed screw, popped in some air from my air nozzle which popped out the piston and seal. Doused in brake cleaner, dried, doused in den-alcohol, dried. Threaded in all the bolts to protect the threads and masked off bolts (unless you want to coat them too) I coated the bleed screw. I did not even mask off the bleader as you couldnt get powder in the hole if you wanted to.. Preheat caliper, coat.. Mine have a lot of contours that the powder did get into the crevices, so hang them accordingly so can do this... I sprayed a little powder on a small acid brush then tapped off the powder into the crevices. Came out GREAT The first one I did not do this and sprayed second coat with caliper hangin the other way to fill the crevices, now I will have to sand blast it and do over. Luck Stimpy |
I almost forgot...
I filled the piston hole with some wadded up tin foil. I made a 5 ply sheet and used the piston to form a round filler. popped it in the piston hole, I did not worry about small spaces as you know how hard it is to get powder into cracks anyway. done.. Stimpy |
OK thanks a lot all. I have a Bare set that I am PC to drive up their eBay value so I will be practicing on them first before I do mine. I have to clean the **** out of them first and outgas them as they are aluminum calipers. Gonna do them in Re-Sale red
One more thing...
I use clear, pure silicone tub and tile sealer.. rated to 400 and I cure 350 for 10 minutes. better than 30-40$$ for plugs... I lay a bead on wax paper, hang it in U shape, cure 2 days.. makes any size you want... plug up those holes Stimpy |
a little triick i use for getting into those damn tight spots is i went down to the sporting goods store and and bought a worm blower...its just a squeeze bottle with a hypo type needle on it..works slick...I also keep an air brush gun with a bit of powder in it near by..
| Chrome brake calipers? | PartTimer | Electroplating Questions | 7 | 10-18-2008 02:23 PM |
| Will polish/plate automotive brake calipers. | norurb | Services Offered/Wanted | 3 | 01-21-2005 02:08 AM |
| PC the brake calipers?? | upncoming | Powder Coating Questions | 11 | 06-24-2004 10:51 AM |
| Color depth vs. anodizing time | NeoMoses | Anodizing Questions | 17 | 02-03-2004 10:06 PM |
| Brake Calipers and hubs | mcarjeff | Other Metal Finishing Questions | 1 | 01-26-2002 09:58 AM |
