everyone makes the in a different way
what I do is start with the lightest color hang the part coat the first color from the top to the middle cure for 10-15 minutes hang the part the same way and coat the second color from the bottom to the middle cure for 10-15 minutes if a third coat will be used if not fully cure here is a picture of one I made http://tinypic.com/54twy |
hey Jt gotta ask somethin.......that cure for 10 to 15 mins..most of the powders i deal with start to jell around 250f........if you start the cooking and then stop it and start again you asking for trouble...? i mean the final cure rate.....the over all duribility cant be good if you interfer with the melt cure cycle....i know it will work........but...will it last?
I have a valve cover that has the letters V8 that will be black while I will do the rest of the cover a different color. I plan on doing the letters first, and doin a full cure then set it over night and then tape off the letters and do the rest the next day.
Blademan I've never had any problems doing it or any complaints
I've had some accidents after finish where some stuff falls of the tables or over them and they haven't chip off or scratch but as for a lasting coat I haven't had any compaints in almost 1-1/2 years I've been doing customers work. Robb letters are not powdercoated they are copy chromed with the flash cooper and copychrome plug and plate kit that caswell sells I chrome the letters and then tape them off with green high temp tape then I powder as normal and remove the tape after finish . |
Is it a haz. process like real chroming? Or is it a safe, do-it-yourself kit. Anyone have a link to that specific chrome kit? I did a search and got a bunch of different ones. I have no clue what to look for. Thanks, and sorry to be such a pain.
http://www.caswellplating.com/kits/plugnplate.htm
you need the cooper and the copy chrome ones they are safe ( non fumes ) you can go to the electro plating area and read how to use them |
| Some newbie questions... | kiwijetpilot | Anodizing Questions | 16 | 03-12-2005 09:18 PM |
| Questions about flat black | melonaide | Powder Coating Questions | 0 | 02-28-2005 09:06 PM |
| Questions | pipefighter248 | Powder Coating Questions | 4 | 11-17-2004 10:05 PM |
| A few newbe questions | thestormfamily | Electroplating Questions | 4 | 06-30-2004 09:54 AM |
| Couple Copy Cad questions | aermakov@rogers.com | Electroplating Questions | 1 | 03-22-2003 12:17 PM |
