any suggestions on cleaning grease and dirt build up on an aluminum intake manifold to get it ready for powdercoat? can i soak it in a solvent or something that wont damage the aluminum's integrety. thanks
the cheapest set up ive found was to buy a meduim size parts degreaser. i fill it with varasol and soak all the parts for up to 24 hours. the parts are scrubbed and rinsed in the tank then set into an empty tub to dry. then i bake the parts for 30 minutes or so to dry any remaining cleaning agent and this also serves to bake any grease or oil and then its off to the beadblast cabinet. once the part is beadblasted its inspected for dirt or contaminents. if its good to go then its off to be washed in a mild detergent then air dried and once again put in the oven for a final dry and pre heat.
sounds like alot of work, but prep is key to getting a good finish. |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Polishing Aluminum Intake Manifold | ScreamingLobster | Metal Polishing Questions | 1 | 08-30-2004 09:00 PM |
| polishing an intake manifold | payneronte | Metal Polishing Questions | 0 | 05-04-2004 02:04 PM |
| Problems with LT1 Intake Manifold | thesound | Metal Polishing Questions | 4 | 11-16-2003 09:54 PM |
| Polishing Aluminum (Engine intake) | RyanT | Metal Polishing Questions | 3 | 02-25-2003 08:53 PM |
