Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 09-30-2004, 01:59 PM
trsick
Default High Temp Powder??
Hey All:
What are you all using for High temp powders, I plan to powder some headers & exh manifolds. Will they stay looking good after heating & cooling while used on an engine? Also if I Powder a intake manifold, does the intake manifold get hot enough to need high temp powder?
Thanks in advance!
Trsick!
Old 09-30-2004, 08:05 PM
customandsound
Guest
Posts: n/a
use tech line that is what i got on mine
Old 09-30-2004, 08:28 PM
johnny933
For intakes we been doing a lot of candy trans. colors over the chrome base and have had no complients. As for the headers, i've hadn't yet to
try the hi temp powders, so cant say. We been using the cerm. coat for headers and the results are awesome.
Old 10-02-2004, 12:23 PM
WAORacing
What are yall using to get the shine for the jet hot lookin stuff that techline makes?
Old 10-02-2004, 01:48 PM
trsick
Default Re: High temp finish
How is the cerm coating applied? I have a parts cleaner, media blaster, Powder gun & a oven. What else would I need to do ceramic coating?
Old 10-02-2004, 02:44 PM
mcaswell's Avatar
Caswell Inc Founder
We now stock Cerakote Chromex chrome ceramic coating. See the web site for application instructions.
http://www.caswellplating.com/powder/ceramics.html
Have A Web Site?
Old 10-02-2004, 03:31 PM
customandsound
Guest
Posts: n/a
i used that chromex ... it is sweet and cheape... i would say if you want a nice chrome look use it .... a compressor and a detail spray gun and don't use glass bead it dose not stick i found that out the hard way ...
here is what i do :
1. clean and degrease
2. i blast it with sand ( it is a healt risk but it makes it bond good)
3. wipe down with thinner
4. spray at 32 psi ( must use filters to tram any water or oil caswell stocks them)
5. i bake it at 500 f for 1 hour
6. polish with 0000 super fine steel wool
7. glass bead at 25 psi and it looks better than chrome plate
  #8 (permalink)
Old 10-03-2004, 10:27 AM
I polish ceramic with 0000 steel wool and sisal wheel with white compound
customandsound -what #of glassbead do you use to blast it after 0000
polish
cuz I have tried some diferent sizes and they still gave me a matte look
so I ended up ussing a polisher but blasting it will be alot easier and faster
  #9 (permalink)
Old 10-03-2004, 11:43 AM
customandsound
Guest
Posts: n/a
i belive it is #8...... i use 25 psi i never tryed the sisal with white...
  #10 (permalink)
Old 10-04-2004, 01:22 AM
WAORacing
Have yall got any pictures of what yall did? I am interested in trying it, just alittle scared to spend that much money and not be satisfied or the customer not be happy with it.
Closed Thread
High temp coatings KeithLambert7 Powder Coating Questions 2 04-30-2005 05:25 PM
high temp sheeting craigcraig Powder Coating Questions 1 08-09-2004 01:15 AM
any experience w/ high temp on headers RossL Powder Coating Questions 2 05-05-2004 09:11 PM
temp of powder coat darkerimages Powder Coating Questions 1 02-10-2004 07:36 PM
Can I use VHT high Temp with Krylon High temp radiator paint magnus Other Metal Finishing Questions 1 05-03-2003 12:20 PM
