Old 09-30-2004, 02:31 PM
sportster883r
Default Two quick questions
First. I have a pretty good size toaster oven for smaller parts, can you hang parts from the overhead heating elements? Second, Instead of buying an air compressor I was going to use a 10 gallon air tank with regulator from sears and just charge with air at my inlaws house where he has a good size copressor. How long will the air (125psi) last with that tank. The manufacter says the gun needs only 8psi at .5 cfm. It seems like the tank can last a while with this setting but Im not sure.
Any help would be great!
Evan
Old 09-30-2004, 09:33 PM
The tank will work fine for small parts and low volume.As for the parts hanging, I don't recommend hanging parts from heating elements.
Old 10-03-2004, 04:32 PM
rlanigan
Hi Sport,
I use my toaster oven as my main oven as I do more small parts.
I tipped mine up on its side, drilled a hole, used a coat hanger to make the hook and on top a handle to turn the parts while curing..
WORKS BAD A$$
JUST DONT, hook the heater elements......
e-mail and I can send pics and specs. etc....
Stimpy
Old 10-03-2004, 08:15 PM
customandsound
Guest
Posts: n/a
Originally Posted by rlanigan
Hi Sport,
WORKS BAD A$$
Stimpy
email me them pic and spec please : customandsound@yahoo.com
thanks
Old 10-04-2004, 07:25 PM
rlanigan
Hi Custom,
Here is my NuBee setup with pics below if it but it works great till I upgrade for my larger parts.
Here is my spray booth, CAUTION, I have a dual exhaust fan in the window next to the box for spraying just in case of overspray.
I also use the shop vac as the box internal powder control. It hooks on top rear and hose is just visible, under it is a 3-layer filter you can get at Home Depot or equiv. to block bulk powder and my vac filter is always clogged with the super fine sawdust as I hook it into most of my wood tools as dust collection, but NEVER until cleaning after powdering first...
The Box has a metal pan on the bottom, grounded for reclaiming powder, and the red rosin paper so powder falling down during spraying does not just flow out on me and the floor...
My oven is just an old toaster oven, set on its side, hole drilled for the hook, and presto, small parts oven, saves electricity too...
Stimpy
http://www.blcustomgraphics.com/imag...dercoat/powder setup 101.JPG
http://www.blcustomgraphics.com/imag...dercoat/powder setup 101 oven.JPG
Old 10-04-2004, 11:09 PM
customandsound
Guest
Posts: n/a
Those links did not work
Old 10-05-2004, 12:55 AM
Stimpy post your pics here
  #8 (permalink)
Old 10-05-2004, 05:46 PM
rlanigan
Here is my spray setup and oven AGAIN, CAUTION NOT SEEN, I have a dual exhaust fan in the window next to the box for spraying just in case of overspray and 3layer filter media under the top flap of the box to filter the powder to the shop vac..
The Box has a flat metal pan on the bottom, grounded for reclaiming powder, and the red rosin paper so powder falling down during spraying does not just flow out on me and the floor...
My oven is just an old toaster oven, set on its side, hole drilled for the hook, and looped the top to turn the parts (just coathangerand presto, small parts oven, saves electricity too...
Stimpy
http://www.blcustomgraphics.com/imag...ersetup101.JPG
http://www.blcustomgraphics.com/imag...tup101oven.JPG
  #9 (permalink)
Old 10-05-2004, 11:00 PM
customandsound
Guest
Posts: n/a
Do you have any pic's of part's you did with this setup? That all reminds me of the good old days when I started ...
Some newbie questions... kiwijetpilot Anodizing Questions 16 03-12-2005 09:18 PM
Gold Tank Plating Questions gofannon Electroplating Questions 0 01-18-2005 03:53 PM
A few newbe questions thestormfamily Electroplating Questions 4 06-30-2004 09:54 AM
Questions from a wanna be... cusackmusic Anodizing Questions 1 01-09-2004 04:45 PM
New here, couple of quick ones (yes I read the manual! :-) Stryder Metal Polishing Questions 22 12-15-2003 06:59 PM
