Old 10-04-2004, 10:26 AM
sportster883r
Default Problem with two coats
I have the hobby type pc gun and have just recently started powder coating with good results. I recently tried two coats (curing in between) and it seems like the powder doesnt want to stick to the first coat. I checked the grouding seemed ok. Do I need to start with a thinner coat. I have not tried clear over anything yet is that easier? Also what causes orange peel? It seems like when I put a heavier coat on it has less orange peel, is this a good assumption?
Thanks again!
Evan
Old 10-04-2004, 05:45 PM
johnny933
Try this when doing two coats jush as translucents over chrome base.
Shot your second color(coat) whilie the part is around 150 degrees.
This is how I do my two step trans. colors and get very great results.
Let me know if this helps.
Flash Copper Problem gwjohnso Plating Pot Metal 12 02-28-2007 12:41 AM
when doing multiple PC coats..... strongtower Powder Coating Questions 4 05-21-2004 01:44 PM
Anodizing Problem???? Cyberave68 Anodizing Questions 3 03-31-2004 03:03 PM
Nitric Acid/Desmut problem....Help Easttex Anodizing Questions 1 02-19-2004 11:59 AM
BEWARE!!! Problem Plating Car with Metallic color paint! GoldiesPlating Electroplating Questions 0 08-29-2003 10:29 PM
