selling a oven?
it has taken me the better part of wo years to develop a low cost high quality oven system just for myself. thier are a lot of different people doing quite a few types of ovens. I've seen really cool stuff to some scary stuff (and most of it turns out pretty decent product. the problem i have found is that it takes about 20 plus hours to build a oven and about $400 for material for a basic 3ft by 5ft by 3ft oven. by the way this size is with out question the most feasible to build to for the size of the average parts you will do. i have oven an myself that will do entire car at one time as well.
I would only build a oven that had the ability to add modules to the end side or top so that if the need arises you can just un bolt the side and bolt on the module. this was harder to devolep than i had ever guesed. you can not run anything through the areas that will come off (wiring sensors elements) and you need to be able to circulate air at different rates depending on cubic ft. i came up with a formula that seems to be spot on for every size so far.
to start with lets look at what the average person is doing. you start with a toaster oven and or a cooking oven depending on what your up to (free to maybe $50.00. lets stick with the cooking oven here. people using toaster ovens or the likes simply dont need a bigger oven. the basic cooking oven is 18in by 18in. by the time you build hangars and give yourself alittle room around your project with placing inside your biggest part is most likly a wheel for a car, and were not talking about a 17in wheel. remember the oven is just 18 inches at the max.
i have taken ovens and simply cut out the back sides etc and built sheet metal boxes and added them with great success. the problem i started running into is saturation (heet) of the part. this was not obivoius to me for quite a while. all you first time oven builders pay attention to this mistake i made and save yourself the time and headache of trying to correct it. if you add on to the oven with sheet metal boxes ( double walled and insulated) you must put burners in the new boxes or create a circulation system to maintain even saturation points and cure times throught the oven.
the point i'm am trying to make or maybe the question i am asking is how many people need to upgrade to a better sytem or would actually take the time to build a oven. I fabricate for a living and know how much is involved to build a topp notch unit that is not hacked together.
at harbor frieght you can buy a powder coat oven 400? it is exactly 18 by 18 inches but with a fan and timers. not a bad system if your looking for something the same size as a oven with these options but i can get as good or better quality product from a free oven thats been sitting in the rain out back for a year.
always remember that good product comes from great prep.
how about everybody that reads this chime in on what they use for a oven if the are currently (actually) coating at this time. or if your thinking of getting started what were you planning on using. also what would you pay for a oven that is of the size i described (1200 to 1500 to be seriuos). one more thing if i made up a set of drawings for a oven and they were free do you think you could actually build them. welding , wiring, sheet metal work etc.
i think it would be intresting to put together a network of peolpe in different areas that would help others to fabricate what they could not build themselves. just food for thought. I would have been pcing a long time ago if i would not have needed a bigger oven than a cooking oven for almost everything i have ever done.
take the time to answer these questions i think if we can compile a little info we could really get a idea of what and where we need to be going. i will be disappointed if this does'nt become the largest thread on this forum, it certainly would give everybody some answers to a lot of questions on ovens and how esay or hard it is for them to get started.
Thier are only two real sports!
boxing and auto racing
all the rest are just games.
Drive it like you stole it!
