Old 11-06-2004, 03:23 PM
11111111's Avatar
11111111
Send a message via MSN to 11111111 Send a message via Yahoo to 11111111
Default solvent tank
i jut switched over my solvent tank to castrol super clean, works great no more solvent fumes in the garge and no more worry about fire. we do a lot of welding in the garage and i was worried about igniting the solvent (happened to my neighbor) so the super clean works as good or better than the solvent and no fire.
Thier are only two real sports!
boxing and auto racing
all the rest are just games.
Drive it like you stole it!
Old 11-06-2004, 03:26 PM
customandsound
Guest
Posts: n/a
same stuff i use... work's even better heated to 125 f ..
Old 11-06-2004, 04:44 PM
11111111's Avatar
11111111
how do you heat it, and does that cause it to evaporate, and if it does evaporate is it just the water that goes or do you replace just the super clean, what ratio do you use. i was going to use it straight but i did not have enuff to get to the pump so i used 1/3 water and it work very well.
Need opinions on my next tank. jtsuttle Anodizing Questions 4 03-29-2004 12:32 PM
Other materials in Anodizing tank? usao Anodizing Questions 4 03-04-2004 09:07 PM
leaving cathodes in ano tank? Sid03 Anodizing Questions 1 01-26-2004 02:10 PM
Tank Heating Questions. meganine Anodizing Questions 1 08-03-2003 03:20 PM
Heaters for a 45 gallon tank jsnow2060 Electroplating Questions 2 01-26-2003 07:47 AM
