Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Old 11-11-2004, 03:35 AM
11111111's Avatar
11111111
Send a message via MSN to 11111111 Send a message via Yahoo to 11111111
Default electronic temp sensor
I could have swore i read a post a while back and someone mentioned using a electronic temp sensor on the part it self. i thought it read something to the affect that it measured restance on the part from the heat change but i dont remember exactly. if some one knows how to make or where to buy this give me a shout out. jeff
Thier are only two real sports!
boxing and auto racing
all the rest are just games.
Drive it like you stole it!
Old 03-16-2009, 07:29 AM
bajabobby is on a distinguished road
Default How much powder
I have finished my spray booth and want to start coating some parts for real. Have coated a few parts and they look great.
But how thick is the coating on my parts and how thick should it be?
Did I put enough powder on?
So is there a cheep way of measuring the mil thickness?
How manny square feet area will 1 pound of powder do at a normal application rate?
Help
Thanks Bob
Old 03-16-2009, 11:04 AM
Harleydad's Avatar
Harleydad will become famous soon enoughHarleydad will become famous soon enough
Default Re: How much powder
Help
Thanks Bob
There are recommended mil thicknesses for every powder, check with the manufacturer.
There are cheap mil thickness gauges that are scraper gauges, but it's a destructive test.
Coverage will depend on the specific gravity of the powder and how heavy it is applied. This info should also be available through the powder manufacturer.
Oven temp vs part temp getastro Powder Coating Questions 4 10-01-2007 01:53 AM
Emissivity setting for IR temp. LouisT Powder Coating Questions 0 05-16-2005 01:04 AM
high temp sheeting craigcraig Powder Coating Questions 1 08-09-2004 01:15 AM
IR Temp Probes getastro Powder Coating Questions 3 07-21-2004 10:12 AM
Can I use VHT high Temp with Krylon High temp radiator paint magnus Other Metal Finishing Questions 1 05-03-2003 12:20 PM
