FREE POWDER COATING SYSTEM
I have been powder coating for a few months. I have always cured as per the label instructions (I have tried a couple different kinds of powder.) I have always had good results but I keep reading where people are curing differently (hotter, cooler, longer, etc.) Is there any way to really know if you are curing properly? Can you "burn" powder coating, like a cake if you leave it in the over too long? I have had batches that were in the oven for about 10-15 minutes to long and I could not tell any difference in the results. Is over curing better than under curing, or are both just as bad?
I think it depends on the powder but it’s a lot easier to under cure than over cure. Most of the powders are pretty tolerant to over curing. Clear doesn’t like to be over cured
I usually pre heat the oven to temperature… load the parts in the oven and wait till it hits temperature then start timing. |
| cure times for powder? | randygrapes218 | Powder Coating Questions | 1 | 07-27-2004 09:00 PM |
| Anyone using the UV or IR lamps to cure. | mattyp | Powder Coating Questions | 3 | 05-15-2004 01:05 AM |
| Cure method for an apartment dweller | skot123 | Powder Coating Questions | 17 | 01-17-2004 11:21 PM |
| Curing Times and Temps | Fireblade | Powder Coating Questions | 5 | 05-22-2003 08:17 PM |
| What is the proper way... | geotexZ71 | Metal Polishing Questions | 1 | 04-08-2003 09:27 PM |
