  #11 (permalink)
Old 12-05-2004, 08:00 AM
viper56
Send a message via Yahoo to viper56
Aaron,
I am still working on a vent design and as far as the fan, it will be wired to a variable speed fan switch so that I will be able to control the rpm of the fan. That switch will be mounted in a double gang box along with a separate switch for the oven light.
Jim
  #12 (permalink)
Old 12-06-2004, 04:37 AM
filburn
Your oven is coming along nicely. Where did you find the lightbulb that can handle 400 degrees? Lowes or Home Depot? Also, when you hook up the vent fan will it start to temp down the oven? I mean there has to be cold air coming in to replace the hot smoke filled air that is being sucked out.
thanks,
mike
  #13 (permalink)
Old 12-06-2004, 07:29 AM
viper56
Mike,
The bulb is a 40w oven bulb from Lowes. You can also get a 100w oven bulb from W.W. Graingers. The fan that I am installing is for circulation and not for exhausting. For the vent and exhaust, I am thinking about putting a piece of galvanized pipe through the bottom of a side panel and one through the top of the opposite side which will go to a collector in a 3" duct and be exhausted outside.
JIm
  #14 (permalink)
Old 12-06-2004, 05:55 PM
Jay87T
I cant wait to see how you wire it up.
Looks nice so far, nice job.
  #15 (permalink)
Old 12-07-2004, 11:42 PM
viper56
More updated pictures as of 12-07-04. (Almost completed)
http://www.stivermotorsports.com/id44.htm
Jay87T,
Thanks, I will post detailed pictures of the wiring and a wiring diagram when the project is completed.
Jim
  #16 (permalink)
Old 12-08-2004, 09:08 AM
ronniej
Hey Viper,
Have you thought about extending your shaft on the fan motor to put it totally outside of the box? I've done some research and others have tried mounting directly with little luck. There's a problem with the internals of the fan not holding up to the heat. Unless, of course if you have a fan designed for this, you shouldn't have a problem. Me and a buddy are in the process of building a gas oven that will measure 4'X4'X8'. We have the frame built and most of the hardware, just no time to get together and finish it due to our work schedule. Also, thanks for taking the time and taking pictures and documenting your progress. This helps out others like me tremendously.
Thanks,
Ronnie
  #17 (permalink)
Old 12-08-2004, 12:37 PM
Leaving some shaft outside the box helps and gives you room to mount a heat sling. It's a small fan blade mounted outside the box.
Makes a huge difference and keeps the motor happy.
Look great Viper!!
  #18 (permalink)
Old 02-07-2006, 08:46 PM
Timmer is on a distinguished road
Default Re: Pics of Electric Oven Construction
ANy idea what happened to Vipers site? Would love to see the pics
  #19 (permalink)
Old 02-12-2006, 06:03 PM
bigeye is on a distinguished road
Hi Viper I cant seem to get your oven pics whats up?
  #20 (permalink)
Old 02-12-2006, 08:37 PM
BigDog's Avatar
BigDog is on a distinguished road
Guys this post is 2 years old
Jeff B.
Instructions for riding a Warrior: 1) sit on bike, 2) start bike and idle till warm, 3) pull in clutch and put in gear, 4) release clutch and rip on the throttle, 5) {VERY IMPORTANT!!} HOLD THE F*** ON!!!, 6) Enjoy!! Side effects may include whiplash, wrinkle free skin, and an evil smile resembling the "Joker".
Cooking up an oven project... dagobert Powder Coating Questions 33 06-09-2008 04:43 PM
advice on oven propane or electric RCC Powder Coating Questions 13 11-26-2006 10:57 PM
pics of my oven and need advice pruettca Powder Coating Questions 4 08-25-2005 12:50 AM
pics of my new oven chicagorich Powder Coating Questions 3 03-22-2005 11:02 AM
Electric Oven Construction Plans viper56 Oven Building Forum 8 08-03-2004 11:20 PM
