Very nice site. I have looked at every page on the powder coating forum, but still have a couple of questions. If I start pc, I will mainly pc motorcycle parts, I was wondering how you all pc the bolts to go along with the part? Also, I am considering an electric oven for smaller parts, but for a frame or set of wheels, do you recommend the ir lights? Probably the 1500. If using the light to do a tubular frame, how do you cure both sides, including top and bottom of the tubing? I am very interested in learning, but need the help of the board. Thanks.
Welcome to the forum
As for IR lamps you'll have to wait for an IR guy to chime in.I prefer ovens but IR works fine too. |
I have p/c'd 2 motorcycle frames so far. Both have turned out awesome. I cured them using a propane lamp and Raytek thermometer. I ended up moving the lamp at 20 minute intervals, first on one side then the other. It took a little over 1 hour, but again, they came out flawless.
I have a 1500 and I barely use it , first you need a completly closed area for it to work
it takes too long to start to melt the powder ( expect at least 50 mins to 1 hour to do a full cure per side) and you will also need an IR thermometer to keep constant readings on the coating. at least this is my experience with my lamp bigger lamps might work better |
| Some newbie questions... | kiwijetpilot | Anodizing Questions | 16 | 03-12-2005 08:18 PM |
| Questions about flat black | melonaide | Powder Coating Questions | 0 | 02-28-2005 08:06 PM |
| First time anodizing questions | scocklin | Anodizing Questions | 10 | 12-04-2004 04:45 AM |
| A few newbe questions | thestormfamily | Electroplating Questions | 4 | 06-30-2004 08:54 AM |
| Couple Copy Cad questions | aermakov@rogers.com | Electroplating Questions | 1 | 03-22-2003 11:17 AM |
