Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 11-19-2004, 02:05 PM
sportster883r
Default Clear coat problem
Ive been using the hobby gun for a lotta pieces and parts and I am now starting to try clear over a color. After the first coat of a standard color is cured I try to spray clear and not enough sticks to coat the part. I thought up two reasons. One, the gun is too weak to charge the clear enough to stick because of the thickness of the first coat, and two, not a good ground but I checked that. Also I tried spraying when the part was hot and that worked pretty good, but I want to be able to do it the other way.
If anyone is not having this problem or if you can help me that would be great,
Thaks
Evan
Old 11-19-2004, 03:55 PM
The clear can be a bit of a pain. Try useing more air and creating a fog over the part. There is less attraction on the second coat so direct spraying can cause more problems than good.With the fogging the clear attracts nicely.
Old 11-19-2004, 08:27 PM
I always spray second and third coats at 150 deg never had any problems .
Old 11-21-2004, 05:52 PM
hvac36's Avatar
Moderator
hvac36 will become famous soon enough
Send a message via AIM to hvac36
I've also spayed the clear and second coats at around 140 - 160 with out any problems..
Jim S..
Jim Shuster
www.backyardpowdercoating.com Sold.....
www.chrissys68mustang.com Hobbie
www.photogserver.net Web Hosting.
Closed Thread
Clear coat temp. limits str8biker Powder Coating Questions 7 07-14-2005 11:17 PM
using clear powder coat after polish? hybred Metal Polishing Questions 10 04-03-2004 03:42 PM
reason for clear coat? Jay87T Powder Coating Questions 14 03-20-2004 12:41 PM
Clear Coat Remover 04sp500 Powder Coating Questions 0 08-04-2003 10:53 PM
prep brushed aluminum for clear coat? jeffb Other Metal Finishing Questions 1 07-23-2002 08:04 AM
