FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 11-23-2004, 01:25 PM
KZjim's Avatar
KZjim is on a distinguished road
Send a message via Yahoo to KZjim
Default Gun trouble....
I have a PC unit from Chicago Electric. The air trigger will not release right away, and it will continue to blow powder for a few seconds after i release the trigger. I thought i was running too little air pressure but that doesnt seem to be the case, Im at 20psi.. I took it appart and cleaned it.. but still does it.. its drivin me mad... has any one else had this problem?
If it jams; Force it. And if it breaks it needed replacing anyway.
I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
Old 11-23-2004, 02:53 PM
hvac36's Avatar
Moderator
hvac36 will become famous soon enough
Send a message via AIM to hvac36
Yup had the same gun, Have to love Harbor Freight but there is a fix,
take the trigger apart again and on the STEM of the trigger apply a little grease NOT ON THE WASHERput back together and leave the packing nut a little loose.. Cured mine..
Jim Shuster
www.backyardpowdercoating.com Sold.....
www.chrissys68mustang.com Hobbie
www.photogserver.net Web Hosting.
Old 11-23-2004, 04:33 PM
Noob2PC's Avatar
Noob2PC
I used Silicon spray to fix mine.
Old 11-23-2004, 05:53 PM
customandsound
Guest
Posts: n/a
8-10psi will work fine
Old 11-24-2004, 12:30 AM
Electrathon
Had the same trouble, was very annoying having to undo the air every time you layed the gun down. Took it apart and lubed it a few times. Finally ended up taking it back.
Old 11-24-2004, 01:12 AM
jagboy69
Same deal here.... I havent had time to take it apart to lube it up, so I just keep a pair of needle nose pliers to pull the thing out when finished spraying... Besides, I'm married so no vasilene around the house
Old 11-24-2004, 11:22 AM
KZjim's Avatar
hvac36... Thanks.. that did the trick, i used tri-flo and left the nut just a bit loose...
  #8 (permalink)
Old 11-24-2004, 03:50 PM
hvac36's Avatar
Moderator
Your welcome.. Glad it worked..
Jim Shuster
trouble with oven wiring myillwillinc Powder Coating Questions 3 06-21-2005 04:46 PM
Trouble shooter guide Blademan Powder Coating Questions 0 09-10-2004 09:32 AM
IR Thermometer reading trouble and fully cured questions Bud Powder Coating Questions 1 07-20-2004 05:36 PM
Trouble getting Sand Blasted Aluminum to take color. LogicPB Anodizing Questions 7 06-05-2003 04:42 AM
Need some help... Newbie polishing trouble. geotexZ71 Metal Polishing Questions 3 04-15-2003 10:05 AM
