Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 11-29-2004, 10:35 PM
makneega
Default Need to remove powdercoat finish. Please help
I am trying to remove a powdercoat finish that is on a very expensive rifle. Don't ask, I did not do it. I bought it that way. It has an aluminum receiver that has the coating on it. What is the best way to remove the finish while not hurting the metal. I don't have access to a sand blaster but I do have a parts cleaner and air compressor. (Don't know if that helps) Any advice is greatly appreciated.
Thanks
Mike
Old 11-29-2004, 10:59 PM
dannydone
Try some Aircraft paint remover from any Auto Zone or Walmart.
Make sure you buy the brush on remover.
Stripping the coat takes some time, but you will be able to do it if you let it sit and use the power washer to remove the bubbled up coating, if cured properly you can simply peel it off the part.
Old 11-30-2004, 01:32 AM
hvac36's Avatar
Moderator
hvac36 will become famous soon enough
Send a message via AIM to hvac36
Mike get if from a Auto Paint Supply house, this was you will get the better of the 2 products. The one you buy at Walmart or the auto store will be Low Odor and takes for ever to work, the one from the Piant supply will be the better of the 2 cost about 30.00 gallon.. But well worth it..
Jim Shuster
www.backyardpowdercoating.com Sold.....
www.chrissys68mustang.com Hobbie
www.photogserver.net Web Hosting.
Old 11-30-2004, 11:27 AM
makneega
I will be stopping by a place today that sells the non-low odor paint stripper.
Should I just place the aluminum receiver in a container with the paint stripper and let it sit or should I agitate the solution around it?
Thanks
Mike
Old 11-30-2004, 01:29 PM
I'd get in touch with the gun maker and find out what alloy the
receiver is made of... cooking the wrong alloy could cause disastrous results with a gun receiver.
Better safe than sorry
Closed Thread
Golf Clubs - How to remove nickel finish prior to refinishin doctordave Other Metal Finishing Questions 3 06-03-2005 04:21 PM
Newbie, trying to find best way to finish aluminum-LONG POST chik Metal Polishing Questions 6 03-14-2005 09:11 PM
Will clear powdercoat dull a polished finish? wozzwinkl Powder Coating Questions 3 09-22-2004 08:53 AM
maximum use temperature of powdercoat finish? paz Powder Coating Questions 2 06-10-2004 12:49 AM
Chrome Plug 'N Plate over gold finish ntd Electroplating Questions 2 06-18-2003 12:04 AM
