Caswell's Bright White and another suppliers Fluorescent Yellow. Problem came in when the other folks supplied the WRONG Cure temps and time sheet.. The right times and temps are 392 Degrees for 7 mins not 15 mins or 325 degrees for 10 mins. Hmm the sheet I received said 400 Degrees for 15 mins, Problem was it was burning the yellow and turning it Orange... ![]() The color is Hard to photograph as well as apply Want to thank everyone again for all the Help.. Thanks folks...
Jim Shuster www.backyardpowdercoating.com Sold..... www.chrissys68mustang.com Hobbie www.photogserver.net Web Hosting. |
Does anyone really know if thier oven is at 392 and not 400 degrees? |
Jim:
I know you stripped it & reshot the frame. Did you try to re-powder over the orange before you stripped? I ask, as I am doing some Ford model T spoke rims using the Caswell "vanilla" powder & the samething (orange in spots) happened to me. I was going to try to reshoot the powder over the orange & then cure at a lower temp? Thought I would ask your results first. Bob www.capecodpowdercoating.com |
The powder I was using was a Top coat over white, But I think you will have the same problems it will bleed thru as the 2 will melt together and the other problem maybe you will get the coat to think and have a chipping problem...
Best to do it right and start from scratch... Let use know how you make out..
| Copy Cad - Yellow Chromate does not stay on | charlton | Electroplating Questions | 1 | 07-31-2005 12:52 PM |
| Copy Cad kit - blackener and yellow cad durability problems | Broke | Electroplating Questions | 11 | 01-09-2005 11:19 AM |
| Yellow Chromate on Galvanized? | Rickc | Electroplating Questions | 0 | 01-31-2004 06:19 PM |
| "Yellow Dichromate, Yellow Zinc" | Rickc | Electroplating Questions | 1 | 01-21-2004 07:22 PM |
| Yellow Chromate & Copy Cad | aermakov@rogers.com | Electroplating Questions | 3 | 03-03-2003 07:28 PM |
