Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 12-07-2004, 10:57 PM
PC4545
Default Oven Builders Help!
HI,
I am new to powder coating and if I'm going to start powdercoating, I want to do it right. I was wonder if I could "gut" conventional electric ovens and use their parts (I would take into account how much space it would need to heat, so I would use the guts from like 3 oven to make my one oven. I can get them cheap off ebay and locally. Then could I just use my own oven shell I made to be the appriate size. I wanted a 3x3x4 or a 4x4x6 oven for motorcycle frames and atomotive things. Will it get hott enough, will 450F do the trick? Sorry to ask all these questions, but I saw Vipers oven's and his parts list and its to pricey for me and I need a cheper way
Old 12-07-2004, 11:43 PM
Electrathon
That is exactly what I am doing. Put out the word and in a month or so you will have ovens coming out your ears. I am using all salvaged parts. Built the box and then transferring over parts.
One thing you might also do if you have the space is to just use one oven as is. You can learn on the smaller oven then progress to bigger and better.
Old 12-07-2004, 11:55 PM
viper56
Send a message via Yahoo to viper56
PC4545,
Here is a link to another oven construction website. He used salvaged oven parts in his construction and just manufactured his own box. You could also use my design and use salvaged oven parts for the guts. I just chose to go with all new parts. You will also find some more inexpensive oven ideas built by members of this forum in past posts. Just do a search.
Jim
http://www.powdercoatoven.4t.com/Index.html
Old 12-08-2004, 12:32 AM
first oven I build
was made out of an old aluminum emegency cabinet of an abandoned hospital it measured 5' high x 3'deep x 6'wide
I used 5 2500 elements and thermostat from old stoves and bought the contactor from ebay
used 2" kanuf for insulation
and it heated up to 600 in less than 10 minutes
and I spend around $300
Old 12-08-2004, 05:33 PM
PC4545
OK, I still don't quite understand how and oven works, This is my understanding, The contactor turns on the heat elements, the thermostat controls the contactor. And how much does an element draw? Per number of elements how manys amps should my contactor be rated for. I understand the vent, thing but what about a Fan? Necessary? I'm 16, but im pretty handy as far as building things, so I'm ready to get building and I want all the tips. Thanks So much for answering all my noob questions.
Old 12-08-2004, 06:17 PM
let say you have 4 elements of 3000 watts
3000 x 4 = 12000 watts
now if you want to use 240 volts
divide your watts by volts
12000 / 240 =50 amp
your contactor need to be bigger than 50 amps
I gave mine a 10 amp bigger size
I don't have a fan in my vent
and haven't had any problems
Closed Thread
Cooking up an oven project... dagobert Powder Coating Questions 33 06-09-2008 04:43 PM
advice on oven propane or electric RCC Powder Coating Questions 13 11-26-2006 10:57 PM
Oven problem !!!!! tavo1765 Powder Coating Questions 7 10-06-2005 06:21 PM
Newbie and oven temperature ? Netnut Powder Coating Questions 2 05-26-2005 10:49 PM
