Old 12-08-2004, 12:32 AM
Electrathon
Default Coating galvinized parts
Everything I have heard says not to coat over galvanization. When doing engine heat shields that are galvanized I have been blasting all the zinc off, a slow process at best. If I just do a good sandblast is that enough, or do I really need to remove all the zinc?
Old 12-08-2004, 01:37 PM
Noob2PC's Avatar
Noob2PC
Default Re: Coating galvinized parts
Are you talking out the Fiero Heat shields if so look in the album as I have done 3 sets of air tubes and upper shields, along with the V6 cross over shields. I just blasted them.
Old 12-08-2004, 07:43 PM
Electrathon
Yes. I know that I can do that and they will coat with an inferior bond. I guess I am just asking how far down the scale this is compared to a proper strip of the zinc. Possibly an answer in percentage or something. Is there 50% less adhesion, 80% less?
The air tubes are very easy, they are aluminum. This is the various galvanized heat shields that are slowing me down.
Old 12-08-2004, 08:30 PM
mcaswell's Avatar
Caswell Inc Founder
An easy way to remove zinc plate is to immerse the part in a 10% solution of muriatic acid. The zinc will go black when it is dissolved. Then a light bead blast will remove the oxide.
You should rinse in fresh water to remove the acid prior to blasting.
Have A Web Site?
Old 12-08-2004, 08:32 PM
Noob2PC's Avatar
Noob2PC
Which heat shield Elect? I had no issues with durability with the ones I did. also shot me an email with your Phone # to nelvar42 @ hotmail.com
Old 12-09-2004, 12:04 AM
Electrathon
Just looked at the ones you have posted in the album, I am doing the same ones. Yours look very good, but if you went over the zinc you will not have good long term durability. As I understand it, zinc is about like coating over painted or rusted metal. It may sort of stick, but nothing by comparison with the extreme durability we expect from powder coat.
Caswell: Thank you! That is exactly what I was looking for.
Old 12-09-2004, 08:47 AM
Noob2PC's Avatar
Noob2PC
Well I cleaned with degreaser, stripped with a wire wheel and then sandblasted them so I think i got the factory coating off.
Copy Chrome on engine parts and plastic, alot of can I's cgworth Copy Chrome Kit Customers Only 3 08-29-2005 12:38 PM
Removal of unknown coating on aluminum rclint Metal Polishing Questions 6 08-25-2005 12:04 AM
Help cleaning just polished parts bonesaz Metal Polishing Questions 3 10-12-2004 06:58 PM
IR heater for powder coating questions dagobert Powder Coating Questions 1 06-12-2004 08:57 PM
Does a coating exist that can be bent slightly? Augest Powder Coating Questions 1 09-22-2003 01:34 PM
