FREE POWDER COATING SYSTEM
I got poor adhesion on some air intake pipes. I used urethane and it went on nice I cured for about 15 minutes after flow, but its chipping off.
Would this be a good candidate for a primer ? I use IR and its cold in my garage..... |
garykelly,
Did you just wait for the powder to start flowing assuming that the part was up to temp, then cured for the allotted time? Or did you use a IR gun to check the part temperature, then started timing it? Jim |
I watched the powder flow. I use an IR gun but my temps have never exceeded 300F even on warm days. I attributed this to curing with an IR lamp...
Other projects that I have done have been very durable this is my first oops.... It could be that while the powder had enough heat to flow, it didnt have enough cure, since I have no way of increasing temperature (other than fabricating a better encloser) is it possible to cure at lower temp for longer times ? The finish was beautiful, no beading, great gloss... |
