FREE POWDER COATING SYSTEM
That's kind of a loaded question. It also depends on the type and amount of insulation you use, as to how much heat you can contain and build up.
Mine, for comparison, is 3 ft by 3 ft by 8 ft deep, and has 4 3200W elements running on a 50A contacter, and the walls are made of 26 gauge sheel metal (HVAC ductwork) boxes containing 4 inches of Knauff 850 degree hi-temp insulation. I've had it up to 520 F and it still had room to climb, and my IR thermometer read the outside skin temp at 72 degrees (in an unheated garage during a night in the 30s). |
At some point it should make it to 400. I wouldn't want to wait that long myself. My oven is 3ftX3ftX5ft, and I'm using 4 2500w elements. The problem you will face with your setup is that it will take a considerable amount of time for an oven of that size to reach the required cure ranges. It will probably cost alot more to heat and maintain temps. It's kind of like using a 4 cyl engine to move a pickup truck...It will do it but you have to keep it pinned the whole time. This will lead to higher power bills and shorter element life. If I were building your oven I would double what you have.
Mine is being made of 20 gauge galvanized steel, and with 3 5/8 of knauff insulation. I will be using my 220v with a 60 breaker that powers my tig welder to provide the juice. I will be using Viper56s wiring set up. I would add third element but i dont know if i have enough juice to power it and i dont know how to wire in a contactor. Can you post a pick of your wiring diagram? if its straight forward i may add a third element. But if my two elements can get it up to temp i wont bother. What do you think?
If you've got 220 on a 60A breaker available, you've got enough to run 4 3200w elements. At 3200w x 4 = 12800w/240V = 53.33A for the elements, plus .7A for the fan (using the same one he did) + .3A for a 40w oven light = 54.33 total Amps draw, and a 10% safety margin with a 60A breaker. I say that because that's what I am using in mine. Be sure to use #6 wire as your main to handle the load to the contactor, and at least #10 from the contactor to the elements wired with two elements per side, and use the wiring scheme from the guy in Texas instead that uses a contactor as a guide. (I believe his website is at www.powdercoatoven4t.com ) I could even shoot a cameraphone picture or two of mine and walk you through the setup, if need be. You'd be FAR happier with the performance of the 4 elements in the bigger space, I'd imagine, although I did find a LOT of other great ideas from Striver's design, too. I kind of used the best of both worlds, and you can probably improve on mine.
I guess I will check the breakers and see which one my Oven is on now. If it is a 30A, what is the Max I can use? 7200 watts total right. That would be umm....4x 1800 / 3x 2400 elements I plan on a 4'W x 4'D x 6'H oven.
Thanks alot for the help, I already have the temperture control that viper56 uses. Will i still be able to use this piece? i hope so because it cost me 200 dollars. Heres a pic of vipers setup, i want to set it up just like this but what i dont understand is where i would set up the contactor. If you know how to use microsoft paint can you draw on the pic where the contactor would go and how it would be wired up. I dont mean to bother you but i would really appreciate the help. If you can snap me some pics of yours that might help to. Thanks again
From the looks of it, the contactor is being replaced by Viper's temp control switch, which I believe he once said was only rated to handle 30A. To make the question simple, you wouldn't be able to simply "add" the contactor into that set-up. Where that has a fused switch and a temp control unit, mine has a double-pole contactor that carries the 240 volts across it, and the off/on action is controlled by taking power off one leg (one side of the two hot wires coming into the contactor) and running it through a 110V light switch to a 110V oven thermostat to a transformer that steps it down to 24 volts, which then switches the low power part of the contactor off and on. Put simply, it's apples and oranges. The difference is, my set-up is made to take full advantage of the 60A available from the breaker, whereas with Viper's you might want to consider changing the breaker and plug(s) to a 30A set-up. in all fairness, Viper's design IS a good one, but it is also designed for the size of oven that he built. Just like mine wouldn't be the best for a walk-in oven, his may not be the most efficent for the size oven you are wanting to build. but if you've already got the money invested in his set-up, you might consider building the oven smaller to match his in cubic feet, and changing the breaker and plug to match what you will be needing. But that's your call, of course. I'm not responsible for what you choose to build or not; I'm just offering my experience from what worked for me.
since i have the parts and im not that good with electrical i think i will just make the oven smaller, im going to go to 3ft tall 3ft deep and 5 or 6ft long hopefully it will work well. Maybe next year i will sell the one i will have and build a bigger one. Thanks for the feed back
| Power Supply Requirements | KomaToast | Electroplating Questions | 1 | 02-26-2004 11:19 PM |
| Requirements to do mutiple finish options | 2bd1 | Electroplating Questions | 0 | 02-21-2004 09:19 PM |
| EPA REQUIREMENTS, PERMITS | harris11 | Electroplating Questions | 1 | 09-14-2003 02:18 PM |
| power requirements for Fast Gold | jomida | Electroplating Questions | 3 | 01-15-2003 10:51 PM |
