  #11 (permalink)
Old 02-19-2005, 05:13 PM
sswee's Avatar
Moderator
The older engines run from 165 to 195 degrees. Most of the newer engines are designed to run 210 degrees. for a better burn. I have used acrylic enamels and polyurethanes on many motors with no problems. PC is better yet. Only on exhaust manifolds or headers do you need the high temp. coatings. As for the ceramic coating, I have only seen headers with this coating. Any coating that hinders heat dissipation too much is going to cause problems. Have you ever leaned on a car after it has sat in the sun all day?
  #12 (permalink)
Old 02-19-2005, 05:32 PM
trsick
Default Re: "Ceramic Coating an Engine Block?"
Thanks Sswee:
I know the engine running temp is roughly 195F. But I thought the heat transfer temp (external) was much higher? Have you had ggod long term results using regular PC? Any idea what a motorcycle engine runs at?
Thanks Again
Bob
www.capecodpowdercoating.com
  #13 (permalink)
Old 02-19-2005, 08:13 PM
sswee's Avatar
Moderator
Can't say off the top of my head what temp. MC motors run. I would have to check but it can't be that much different even considering it being air cooled. Too much temp causes oil break down and detontion just to list a few. I have a 78 KZ1000 Police and a 82 Harley XLS. I can tell you the majority of colors on Harley motors is PC. The PC I have, I had done and it holds up better than any paint. I am just trying to get set up for PC now. Catalyzed polyurathane used to run a tight race with PC but since paint manufacturers pulled the lead out it don't seem as durable to me anymore.
  #14 (permalink)
Old 02-19-2005, 08:37 PM
hvac36's Avatar
Moderator
hvac36 will become famous soon enough
Send a message via AIM to hvac36
Ive PC'ed at least 2 dozen engines and the oldest 1 is about 3 years old and still looks like new...
Getting ready to PC a 289 out of my 68 mustang.
Jim S...
Jim Shuster
www.backyardpowdercoating.com Sold.....
www.chrissys68mustang.com Hobbie
www.photogserver.net Web Hosting.
Anyone done an engine block? BlindUmpire Powder Coating Questions 18 10-08-2005 09:59 PM
Powder Coating Engine Block and Heads falconx Powder Coating Questions 3 07-21-2005 01:08 AM
Powdercoating an engine block Riaanc Powder Coating Questions 1 05-20-2005 09:58 PM
Anybody ever polished a cast iron engine block? thesound Metal Polishing Questions 5 02-10-2005 11:31 AM
Anyone know where I can get a block of ceramic MattAnonymous Other Metal Finishing Questions 2 07-07-2004 02:34 PM
