curing to directions of the powder.oven temp is accurate i am able to maintain my heat with in +/- 7 degrees. as far as part temp i just allow plenty of time to cure. just doing some small sample pieces right now trying to get a smoother finish. no problem with the clears.
I stay down around 325 for 25 min to get a smooth finish. This allows the powder to stay in a wet state longer.Sometimes waves come from the part curing too fast.The powder cures before it has enough time to flow properly.
Watch how thick you apply the powder and the cure time.
This is Candy Apple Red ( Chrome base) .. Jim S...
Jim Shuster www.backyardpowdercoating.com Sold..... www.chrissys68mustang.com Hobbie www.photogserver.net Web Hosting. |
On rounded surfaces absolutely, larger flat surfaces get harder to get that paint look.You can get an oem paint quality simple enough but going for a perfect finish is simply experience.
As an added note I forgot to ask earlier, are you media blasting the part?I'm assuming you are, most people do,try sanding the part after blasting with a fine paper.Just remove the high spots don't go overboard.You don't need to sand it perfectly smooth. |
| Golf Clubs - How to remove nickel finish prior to refinishin | doctordave | Other Metal Finishing Questions | 3 | 06-03-2005 04:21 PM |
| Newbie, trying to find best way to finish aluminum-LONG POST | chik | Metal Polishing Questions | 6 | 03-14-2005 09:11 PM |
| What finish for a gold Freewheel ?? | systemBuilder | Electroplating Questions | 0 | 03-06-2005 10:33 PM |
| can we identify this finish? | funkmunky | Electroplating Questions | 3 | 12-15-2004 09:45 PM |
| Chrome Plug 'N Plate over gold finish | ntd | Electroplating Questions | 2 | 06-18-2003 12:04 AM |
