FREE POWDER COATING SYSTEM
If your oven has an element(s) like an electric kitchen range, it won't matter if you run it single or multi-phase. It operates the same. Most commercial buildings only have 120/208v available. This means all the equipment used must be able to run off either 120 or 208. Look for a tag that says what the voltage requirements are. Most likely it'll say a range like 206-250v. If that's the case, put a double-pull breaker in and wire up a dryer plug so it runs off 240v. There's most likely a wiring schematic inside the electrical box attached to your oven. Read what the amperage requirements are as well to be sure you size your breaker sufficiently. Use amps = watts / volts. E-mail me if you need more info.
Don |
The service is giving me 80amps from the box, the oven will draw about 68amps, so basically 70amps will be needed, wired 230vac with 4 elements 2500kilowats each plus controll etc..
I wired it up today and had a voltage drop that got the oven running at or around 204vac, so I got it wired up with a new transformer to stabilize the voltage at plus or minus 10 percent of 230vac, see what happens tomorrow, I need to get a new semiconductor contactor with heatsink (2pole) with at least 70amps because the 3 phase 50amp is toast. |
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 03:43 PM |
| More gas oven questions and a few good links | BikerBill | Oven Building Forum | 9 | 03-06-2006 12:31 AM |
| Oven problem !!!!! | tavo1765 | Powder Coating Questions | 7 | 10-06-2005 05:21 PM |
| Hi new to board and have a few oven questions | chicagorich | Powder Coating Questions | 4 | 12-30-2004 07:08 AM |
