any one done any playing around with pc'ing wood much? Did a few chunks the other day to just see what would happen and was rather surprised at the out come, it actually looked better than my rattle can paint jobs . I did have trouble with the laminated chunks sort of an out gassing effect but i would guess that was do to the glue that is used.
Pro-Tech Powder Coating 93976 Ocean Way 541-247-8168 protech@harborside.com Gold Beach,Oregon |
a few months ago I started looking for the same thing .
tried a few parts but it didn't work as good as metal so started making calls and found that you need UV curable powders www.protechpowder.com has a powder called nuvocoat that only needs 175 degrees to melt and then cure by Ultra violet http://www.protechpowder.com/products/nuvocoat.html |
been playing......hard wood it seems gives a better finish than laminated wood, i think the prob with the laminaed is the gluethats used,also I seem to get a better finish when i put the powder on rather thick.
I have been reading up on PC over wood. I read they sell an aerosol spray that will make wood conduct static electricty, so the powder will cling. They also write that "MDO" board works better if you want to do a laminated wood product. I guess the "MDO" board uses adhesives that will withstand the curing temps.
Good Luck Bob
www.capecodpowdercoating.com |
kinda of a hijack, but does anyone know of plastics that willstand the curing temp? maybe a model resine or something. Just curious because I have seen plastic coated with a metallic coating, then chromed. it would be really useful for creating one-off emblems and such.
| Powder Coating Wood? | pleximan | Powder Coating Questions | 3 | 10-22-2003 05:10 PM |
| distilled water?? | scopenut | Electroplating Questions | 10 | 06-08-2003 11:24 PM |
