i am assuming that the alligator clip that you connect to the part you are coating is grounded to the chasis of the compressor, which is grounded to your wall outlet, assuming it has a ground port. my question is if you have an old style plug can you just take your alligator clip and attach it to an earth ground?? i believe all grouned electrical circuits are ground to an eight foot ground rod anyways. just want to make sure this is all correct.
LinkBack URL
About LinkBacks
