Old 03-07-2005, 02:52 PM
trsick
Default Powder of Zinc plating.
Hey All:
I have a customer that wants my to PC on items that had been previously zinc plated. Do I need to do any special prep? Or do I need to blast off the zinc coating first
Thanks
Bob
www.capecodpowdercoating.com
Old 03-07-2005, 03:15 PM
CaptainChauncy is an unknown quantity at this point
I just blast off the zinc coating and then treat it like a normal part. It probably wouldnt hurt to prebake it though. Ive only powdercoated a couple small parts that previously had a zinc plating but they came out great
Old 03-11-2005, 12:17 PM
pdeinc
Whether you get all the zinc off or not is pretty much immaterial. It's a metal, not much different than any of the fillers used to prep parts with. More important is that it's clean.
Old 03-11-2005, 01:10 PM
Zinc Plating Guru
I've been PCing zinc palted parts quite successfully. Zinc is a great base for PC. Some pictures:
http://www.hogheaven.com/hobby/plati...tes/index.html
If the zinc parts have a chromate conversion coat, simply cleaning them good should be enough. Chromate coversions are a good base for PC.
If the parts are raw zinc, pre-etch them for about 10-20 seconds in a 3-5% muriatic acid pickle. This will remove surface oxidation & activate the zinc surface.
Sean
Old 03-11-2005, 05:30 PM
customandsound
Guest
Posts: n/a
i spray right over it .. clean it real good !!!
Zinc plating on running seal surface? Broke Electroplating Questions 1 12-06-2004 02:52 PM
CopyCad & Zinc failure - electrolyte problems? seanc Electroplating Questions 4 11-08-2004 10:16 AM
Powder coat over zinc plate? sccc Powder Coating Questions 4 08-01-2004 12:47 PM
NEED HELP QUICK!!! Yellow Zinc Plating Fasteners BryanD Electroplating Questions 1 05-01-2004 01:34 PM
Plating Tank - Zinc aermakov@rogers.com Electroplating Questions 1 03-27-2003 02:38 PM
