hey my web cam at yahoo is on watercatwn6535nd@yahoo.com com take a peak at my new oven.
Thier are only two real sports! boxing and auto racing all the rest are just games. Drive it like you stole it! |
here are some pitcs that i pposted in caswells photo section
http://www.caswellplating.com/bbs/album_personal.php
Looks good. Is that a timer next to the thermostat?
www.tinmans.net "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW--What a Ride!!!" ----- Unknown |
Looks good man! This is exactly what I will be doing, when I build my bigger oven. I currently use an old deep freeze (outside incase the linings decide to go) which they haven't yet. The torpedo with the deep freeze at least gets to temp (450) easily within 5 minutes.
Would you mind explaining what you did to connect that thermostat, and is the timer set up to auto shut off the oven? Thanks again for the post, I knew this idea would work, and with your completion of the oven, you have proven that this idea has hope. Thanks again Brian |
I tried to look at the pic's via both the links you supplied, no go? Can you email me pic's @ trsick@aol.com?
Thanks Bob
www.capecodpowdercoating.com |
Bob,
Go to Album link at top of page and scroll down almost to the bottom of page where it says Users Personal Gallery,. Click that link, then scroll down to 11111111. Or, go here: http://www.caswellplating.com/bbs/al...p?user_id=9436 Leo
getastro
Cut a regular extension cord in half, wire the hot wire on the male end to the input terminal on the thermostat and the hot wire on the female side to the burner (switched) side of the thermostat. Then wire nut the 2 neutrals together and the 2 ground wires together. The thermostat will work like an inline switch controlling the heater. Plug the extension cord into a regular wall outlet and the heater into the extension cord. I have a 4' x 6' x 6' oven heated with a 150,000 butane propane torpedo heater and it works great. Hope I didn't confuse you with my wiring explanation. Leo
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 04:43 PM |
| advice on oven propane or electric | RCC | Powder Coating Questions | 13 | 11-26-2006 10:57 PM |
| Oven problem !!!!! | tavo1765 | Powder Coating Questions | 7 | 10-06-2005 06:21 PM |
| Newbie and oven temperature ? | Netnut | Powder Coating Questions | 2 | 05-26-2005 10:49 PM |
