Old 03-08-2005, 12:21 PM
trsick
Default How long will the powder hold until it needs to be cured?
Hey All:
I just finished my big oven (8'x8'x8') last week. I plan to powder many items & then bake them all off at the same time at the end of the day. My question is... How long will the powder stay static while I wait to cure? Will I risk loosing the static charge if I wait too long?
Thanks
Bob
www.capecodpowdercoating.com
Old 03-08-2005, 05:12 PM
tinbender722 is an unknown quantity at this point
Send a message via AIM to tinbender722 Send a message via Yahoo to tinbender722
It should be okay. Just stack the pieces in the oven where they won't be contanimated until it is full.
Leo
www.tinmans.net
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW--What a Ride!!!" ----- Unknown
Old 03-08-2005, 05:29 PM
trsick
Default Re: How long will the powder hold until it needs to be cured
Thanks Leo!
Old 03-08-2005, 09:24 PM
randygrapes218
i agree the biggest problem with doing that is contamination of dust particles floating around
Old 03-08-2005, 10:04 PM
you won't have any problems
I've done up to 15 parts at the same time
just don't mix up colors in the same batch,learn that the hard way
Old 03-10-2005, 03:47 PM
mtumbleson
In regard to storing the pieces in your oven, would it be OK to bring the oven up to temperature with the pieces hanging on the rack?
Old 03-10-2005, 06:13 PM
sheldonross
Actually I believe the concensus is that bringing parts to temp with the oven Helps the process, under the chrome thread, its recommended as a process to try in order to get your chrome to cure best.
  #8 (permalink)
Old 03-10-2005, 10:43 PM
11111111's Avatar
11111111
Send a message via MSN to 11111111 Send a message via Yahoo to 11111111
I always pre heat or out gas the part at 450f then turn the temp to 200f and wait for the oven to cycle on at that temp so i know it is at 200f. then i spray it close the door set to the temp i need for full cure and set the timer. I never shoot cold parts and hot parts coat just like there staticly charged. give it a try if you have not been coating this way i think you'll be suprised at how much easir and better quaility work you will turn out.
Thier are only two real sports!
boxing and auto racing
all the rest are just games.
Drive it like you stole it!
  #9 (permalink)
Old 03-10-2005, 10:46 PM
mtumbleson
I tried it today and didn't see any problems with it.
I have a small oven and do small parts I machine. I found it helpful because I could load the oven without hurrying and getting burned, messing up the powder and having to re-shoot the parts. And by adding the pieces in the oven while its cold, allows me get more pieces in the oven per run, about twice as many as I was doing before.
  #10 (permalink)
Old 03-10-2005, 10:52 PM
11111111's Avatar
11111111
you lost me there, you do load and spray or you powder cold then put them in the oven
Tips and Tricks non-stick Powder Coating Questions 27 11-11-2007 02:01 PM
powder coating over powder coat? corybarta Powder Coating Questions 6 08-21-2006 08:15 AM
Taping over cured powder for a second color corecoatings Powder Coating Questions 3 06-21-2005 06:07 AM
Finding a place to powder coat RCLSolutions Powder Coating Questions 3 05-04-2005 09:42 PM
Gun spitting excess powder pdeinc Powder Coating Questions 8 10-21-2004 03:21 PM
