Old 03-12-2005, 06:15 PM
cabrego
Default My PREP WORK : Pics INSIDE>>>Comments??
Hey guys I am expecting the starter kit in a few days. Here is a link to some of the parts will be coating. I would appreciate any comments or advice. Also, is it ok that there is minor scratches from sanding and the di grinder? Will the PC cover it fine? Let me know what ya think.
These parts are almost oil free, but they do not pass the white glove test yet. I plan for one more stage of degrease before they get coated.
Thanks!!
http://pg.photos.yahoo.com/ph/nukeca...pg&.src=ph
Old 03-12-2005, 06:21 PM
cabrego
Couple of more links: valve covers, and pullies.
Old 03-12-2005, 08:16 PM
CaptainChauncy is an unknown quantity at this point
I've always sandblasted my parts that are going to be powdercoated. Sandblasting them would be much faster than sanding them down. If you dont have access to a sandblaster try finding a local shop that will sandblast them for you.
Old 03-12-2005, 08:34 PM
cabrego
Thanks for the comments, believe it or not, these parts have been soaked in a simple green mixture, scrubbed, sand blasted, and only one of the valve covers has been sanded. Not a major difference between the two.
I thought they looked pretty good, did they not look clean to you capt'n?
Let me know, I want to do it right the first time.
Old 03-12-2005, 08:53 PM
I usually just degrease, sandblast, and preheat the parts to be coated. So if you did all that you should be fine. Make sure to preheat the parts to get any chemicals out of the part. It will save you from having to strip the parts again
Old 03-13-2005, 10:41 PM
cabrego
Anyone else have comments or advice?
Also, since I have not actually recieved the kit yet, I have a question about pre heating. How long should I do it and what temp? When I am actually coating the part, can the part be at room temperature??
Let me know, thanks guys!!
Old 03-14-2005, 10:49 AM
I also use simple green for degreasing. One suggestion I have for you is to heat it to about 90 degrees or so. There are many submersible heaters that will do the trick. After the parts are clean, I heat them up in the oven then clean em again, depending on how greasy they are, and what they are made of. Good results depend on good prep.
  #8 (permalink)
Old 03-17-2005, 06:06 PM
cabrego
well, from what i gather, I should still decrease these bad girls till they pass the white glove test.
my starter kit arrived, but I out of town. Owell, any other comments??
  #9 (permalink)
Old 03-17-2005, 10:57 PM
11111111's Avatar
11111111
Send a message via MSN to 11111111 Send a message via Yahoo to 11111111
ford parts never turn out well, really it wont be your fualt so dont worry to much about it. C'MON IT'LL BE PERFECT and if its not just blast it back down. I remember my mistakes better after i have had a few hours of blast time to re think the whole screw up.
Thier are only two real sports!
boxing and auto racing
all the rest are just games.
Drive it like you stole it!
  #10 (permalink)
Old 03-18-2005, 06:57 PM
cabrego
ya, those damn fords use a different aluminum ive heard
Pics of Electric Oven Construction viper56 Powder Coating Questions 19 02-12-2006 08:37 PM
PREP. WORK >>> ? Sezer Powder Coating Questions 1 05-25-2005 11:22 AM
prep before powder coating cryzko Powder Coating Questions 1 03-30-2004 02:52 AM
Prep work before chrome fat_bob155 Metal Polishing Questions 4 06-23-2003 11:33 AM
Polished wheel pics! blip01 Metal Polishing Questions 4 04-25-2003 09:19 AM
