I ordered some charcoal metallic from caswell and it says I need to top coat it with a clear top coat. I looked on the web site and cannot find a clear top coat to order, where is it and how do you use it. thanks
Blast the piece, sand with 220 grit wet sand paper to knock down the profile from blasting, metalics work by reflective and the smoother the surface the smoother the metalic coatings.
Rinse with water, air dry. Pre heat part in oven at 440f for 30mins to outgass the metal Take out and allow to cool to touch and powder coat Place in oven at 375f for 20mins, pull out wait 3 mins then coat with clear place back in oven and cure at 400 for 15 mins |
I would suggest to clear coat at 150 deg
wating 3 mins then clear you might coat at 200 or more easily wich will cause the powder to melt almost instantly and causing orange peel and all kind of weird things . the best way is caswells Infrared Thermometer but if you can't aford it go to a local hobby shop and buy an Infrared Temperature Gauge or gun made by duratraxx or ofna , it will cost $20-$25 and it will save you a lot of head aches |
| METALLIC SILVER? | randygrapes218 | Powder Coating Questions | 3 | 03-19-2005 08:58 PM |
| Charcoal Metallic vs. Brushed Nickel Metallic | mdhoward | Powder Coating Questions | 1 | 09-17-2004 11:00 PM |
| reason for clear coat? | Jay87T | Powder Coating Questions | 14 | 03-20-2004 11:41 AM |
| BEWARE!!! Problem Plating Car with Metallic color paint! | GoldiesPlating | Electroplating Questions | 0 | 08-29-2003 09:29 PM |
