+ Reply to Thread
Results 1 to 4 of 4
Thread: Converting a syphon media cabinet to a pressure cabinet?
  1. #1
    Join Date
    Jul 2004
    Location
    Cape Cod Mass.
    Posts
    157
    Default Converting a syphon media cabinet to a pressure cabinet?
    I have a Cyclone syphon media cabinet (FT6035) 60" top loader. I am not happy with it's performance. I have a 7.5 hsp. - 2 stage air compressor delivering up to 175 psi with 27 cfm. So I don't believe the air supply to be the problem.
    I am considering converting the media delivery form syphon to pressure. Any one have any BTDT advise?
    Thanks
    Bob
    Share with Facebook
  2. #2
    Join Date
    Nov 2004
    Location
    Mississippi Gulf Coast
    Posts
    85
    Bob
    I think about the only way to do that is going to be with an external pressure pot blaster. I have my small cabinet set up that way now. Ask questions and I'll try to answer them.
    Leo
    www.tinmans.net
    "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW--What a Ride!!!" ----- Unknown
    Share with Facebook
  3. #3
    Join Date
    Jul 2004
    Location
    Cape Cod Mass.
    Posts
    157
    Default Re: Converting a syphon media cabinet to a pressure cabinet?
    Thanks Leo:
    So pretty much, route the pressure pot next to the cabinet. Using the hose directly from the pressure pot to inside the cabinet? Once the media runs out, I can dump the media out the bottom, screen & refill the pressure pot? I guess I would need a different nozzle (replacing the syphon gun?
    Am I on the right track?
    Thanks Again
    Bob
    Share with Facebook
  4. #4
    Join Date
    Nov 2004
    Location
    Posts
    85
    That's pretty much it, Bob. I did modify my pressure pot so that it is operated at low pressure - about 7 lbs. I also replaced the pressure gun that came with the blast pot with a Husky siphon gun from Home Depot. I supply 80 lbs. of air at the gun and sand is delivered to the gun at about 7 lbs. Using this setup, I can blast for about 30-40 minutes pretty solidly with 50 lbs. of glass bead. It just works a lot better than siphon blasting.
    Leo
    www.tinmans.net
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
