Old 04-01-2005, 08:12 AM
VPC VPC is offline
VPC
Default Pressurized blaster?
Would pressurizing my cabinet really give an increase of 4-5 times faster as they claim?I have about 130 lbs. continuous pressure and good media flow.But I am considering adapting my pressure pot to the cabinet.Would it be worth it? Thanks Steve
Old 04-01-2005, 11:09 AM
Zpider
We normally use an ordinary siphon kind of blaster in our cabinet, but when i get reall nasty things to blast i use the pressurised blaster pot hose in the cabinet. You cant even compare them, its like you upped the pressure by 200%.... so on stuff that have a few coats of urethane like paint on it, like some wheels, yes, i would say 4-5 times faster minimum since the siphon dont even bite on it...
WEIRD Performance & Coatings
Sweden
Old 04-02-2005, 11:19 AM
trsick
Default Re: Pressurized blaster?
Hey Zpider:
I have both the syphon cabinet & a walkin booth with a pressure pot. Seems I always have trouble with the pressure pot either using the media to fast, & or clogging, even if I use strickly virgin media? What are you doing? How long & how much media does it take you to blast a set of wheel (2 @ 15")?
Anything I can do to reduce prep time is a good thing!!
Thanks
Bob
www.capecodpowdercoating.com
Old 04-02-2005, 01:12 PM
Zpider
Whells are a pita, some have urethane paints that wont come off easy, in hours, well, all from half an hour to half a day on 2 wheels. The pots are tricky to get adjusted for the right flow, take a bit of jiggling to get it set up.
Sweden
To go Cabinet or Pressurized? bkoenig Powder Coating Questions 8 02-01-2005 12:24 PM
sand blaster / bead blaster? Chevalier Anodizing Questions 2 02-07-2004 03:15 PM
