FREE POWDER COATING SYSTEM
I built a 6 foot tall by 4 foot wide by 2 foot deep oven with 4 burners at the bottom. The digital oven temp gage reads 400 degrees but the parts only get around 325 degrees. I am using an infared temp gun to check the parts. If I need a fan should I mount it down by the burners or clear at the top.
I have a fan that turns 1550 rpm's, I am thinking about putting it in and hooking up a switch to it so I can turn the rpm's down, just like on house lights, that kind of a turn knob switch. will this work. thanks guys |
Careful with the infared temp gun.It will give false readings on anything that has a shine or gloss.Try taking your readings from different areas on the part.As far as vents my large oven has none.Fan circulates air through the oven in a closed system.Circulation will make for a more even cure.You will be less likely to have hot spots.
I put a fan in yesterday and the thing got so hot it quit working, after it cooled down it would run again. I drilled a 1/4 inch hole in the side of the oven an inserted the shaft and put the fan on the other side. It worked fine until it got hot then quit. I had it at full operating speed. I think I have it to close to the burners. I might mount it on the top of the oven this time. Actually the oven does work fine without the fan. I have found out that I have to bake everything longer to make it work rite. thanks
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 03:43 PM |
| advice on oven propane or electric | RCC | Powder Coating Questions | 13 | 11-26-2006 09:57 PM |
| Oven problem !!!!! | tavo1765 | Powder Coating Questions | 7 | 10-06-2005 05:21 PM |
| Newbie and oven temperature ? | Netnut | Powder Coating Questions | 2 | 05-26-2005 09:49 PM |
