+ Reply to Thread
Results 1 to 7 of 7
Thread: powder coating over powder coat?
  1. #1
    Join Date
    Nov 2004
    Posts
    75
    Default powder coating over powder coat?
    I know this has been disscussed before, I have read that you can powder coat over powder coating by sanding it then coating over it. I have tried this and the new powder does not stick to the part. I have even used my sand blaster to roughen up the surface and it still wont stick to the part. I find my self having to completely blast the part down to bare metal again to get it to work properly. Any help would be appreciated. Will the powder get and a charge threw the old powder
    Share with Facebook
  2. #2
    Join Date
    Mar 2004
    Location
    Gold Beach, Oregon
    Posts
    322
    try a new ground point and re-heat the part, i like to use around 150 .
    Pro-Tech Powder Coating
    93976 Ocean Way
    541-247-8168
    protech@harborside.com
    Gold Beach,Oregon
    Share with Facebook
  3. #3
    customandsound Guest
    just scuff it with 320 and in a spot that is not noticeable i scratch it down to the bare metal to get a good ground. and i test my arc it the arc is light i turn the air down to 8-10 it i got a good arc i shot as i would a fresh part.. it the arc is to light with the hobby gun i will switch over to my pro gun and get it done...
    Share with Facebook
  4. #4
    Join Date
    Dec 2004
    Location
    Freedom Vale
    Posts
    93
    Default Re: powder coating over powder coat?
    I have had luck just using the actual first hook through the whole process. Obviously it takes a bit more on a second coat being that it is a 20kv gun.
    Once that hook is in a hole, it should be a decent contact point. Good luck!
    Share with Facebook
  5. #5
    Join Date
    Dec 2004
    Location
    Overland Park Ks
    Posts
    82
    I have done it before, I used a friends shop with his progun. First I went over the part with steelwool and also baked it 10min longer than the powder called for.
    Share with Facebook
  6. #6
    Join Date
    Mar 2006
    Location
    Ohio
    Posts
    93
    There shouldnt be much of a problem if the part is reheated again.
    Just think of it as a 2 step coating job anyways. like all the base/clears.
    Shoot it hot and you shouldnt need a good ground. But keep a eye on how much powder you lay on the part.
    Share with Facebook
  7. #7
    Join Date
    Jul 2005
    Posts
    87
    yea I see that message getting deleted pretty fast. This is a caswell board I do not think they would like you trying to get business off it.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Finding a place to powder coat
    By RCLSolutions in forum Powder Coating Questions
    Last Post: 05-04-2005, 09:42 PM
  2. Laser printer = Powder Coat Printer?
    By tbloss001 in forum Powder Coating Questions
    Last Post: 08-30-2004, 06:08 PM
  3. Magnesium-sticking powder coat to it and the cleaning proces
    By fst951 in forum Powder Coating Questions
    Last Post: 04-14-2004, 01:53 AM
  4. Non-paint powder coating
    By dshepherd in forum Powder Coating Questions
    Last Post: 01-26-2004, 11:49 AM
  5. Powder coating process..
    By tomg552001 in forum Powder Coating Questions
    Last Post: 01-14-2003, 07:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
