Old 04-22-2005, 12:23 PM
gtabadboy
Default What sand can be used to sandblast powder off aluminum wheel
I want to strip some motorcycle wheels and powder them mirror chrome. What can I use and what grit when sandblasting. This is the factory powdercoat. Thanks I assume that the mirror chrome will look better if I strip this layer right?
Old 04-23-2005, 07:50 AM
Blademan's Avatar
Blademan is on a distinguished road
your gonna be blasting awhile, I would use something like jasco and let the chemical do the work, then blast it..
Pro-Tech Powder Coating
93976 Ocean Way
541-247-8168
protech@harborside.com
Gold Beach,Oregon
Old 04-23-2005, 09:55 AM
gtabadboy
What should I do to make sure I dont get any reactons after using a chemical to strip. Whats the best method to clean all the chemical off the wheel before powdering? Thanks
Old 04-25-2005, 01:01 AM
customandsound
Guest
Posts: n/a
put the part in a household oven set it on clean800f it will help remove the coating as long as you don't heat the metal above 950f you will be ok around 1000 the metal will soften up and start to distort at 1200 you better get a pot it will be in the pre metal stage
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Photo album - motorcycle wheel with rainbow flake... powder? mtnbiker Powder Coating Questions 7 04-11-2005 04:28 PM
Powder Coating Stripping from Aluminum kaleem1 Powder Coating Questions 0 11-24-2004 02:54 PM
:?: steps to powder coating aluminum? i'm new REXPWR Powder Coating Questions 3 09-15-2004 12:32 AM
Can I powder coat polished aluminum? remotestartdepot Powder Coating Questions 3 05-20-2004 11:00 PM
