FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 05-01-2005, 06:10 AM
overcoat
Default Mounting wheels
Hi,
How do you guys hang rims whilst Powder coating them?
Thanks,
steven
Old 05-01-2005, 04:23 PM
Relfn
Depends on the rim... I usually try to bend a hook out of round stock that will minimize any rack marks. It's worked well so far.
Old 05-01-2005, 10:19 PM
customandsound
Guest
Posts: n/a
i wrap a chain around them and hook it with a s hook .. then hang the tire hides the chain mark when powdered... the chain is good for 4 set's of wheels then you need to either burn the powder off or blast it .. i burn it with the torch then glass bead it to get what ever is left
Old 05-02-2005, 02:24 PM
trsick
Default Re: Mounting wheels
I too use a chain. I wrap the chain around the rim center. Once the tire is mounted you never see where it was hung from.
Good Luck
Bb
www.capecodpowdercoating.com
Old 05-02-2005, 09:22 PM
Heavykote
I hang mine from a hook at the valvestem. A little area is missed, but when the valvestem is replaced you can't even tell. I also coat both sides of a rim. I will try the chain method. Thanks guys...
Old 05-02-2005, 09:31 PM
customandsound
Guest
Posts: n/a
i used the eye bolt in the valve hole but with the chain it works perfect.. + i had complaints about that part not being done..
when i coat them i hit the front 2 times the rear 1 then the same with the clear ...
Old 05-02-2005, 09:45 PM
KZjim's Avatar
KZjim is on a distinguished road
Send a message via Yahoo to KZjim
for steel rims i have a stock if ceiling grid wire and use the arc welder to stick it to the rim.. then just knock it off when im done.. for alum i just wrap the wire around and hook it..
If it jams; Force it. And if it breaks it needed replacing anyway.
I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
  #8 (permalink)
Old 06-29-2005, 03:06 AM
nuttyman's Avatar
nuttyman
I make jigs out of 1/2" box tubing. I thread 1'4" holes every 120 degrees to clamp the under side or inside the wheel. the jig is in the shape of a "Y" with pieces welded squarely to the ends of the Y. it makes a great jig & is easily hung & rests nicely in the oven with the wheel supported in the middle of the oven. e-mail me @ dlrracing@cableone.net & i'll send ya some pics of 'em. here is a lousy pic of 1 of the 1st jigs I made!
nutty
wheel jig
  #9 (permalink)
Old 06-30-2005, 12:22 AM
customandsound
Guest
Posts: n/a
when i do my bike wheels i hook them with chain the tire will cover the centers
Cant get compound onto the wheels 1105 Metal Polishing Questions 3 04-28-2004 09:05 AM
Where to buy buffing wheels Holmespolish Metal Polishing Questions 0 04-02-2004 12:53 PM
Where to buy buffing wheels Holmespolish Metal Polishing Questions 0 04-02-2004 12:52 PM
Polishing truck wheels with minor corrosion karter03 Metal Polishing Questions 0 02-19-2004 03:04 PM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 08:12 AM
