Old 05-02-2005, 01:55 PM
Noob2PC's Avatar
Noob2PC
Default Yes, the Infamous OVER WIRING Questions again :shock:
Been busy with about 20 different things and a Charity event. I recently picks up 2 Cabinets that I will be using to make my big over. It will end up 6' x3.5' x 3.5'.
I intend on running 4x Elements but not sure if I can use one set of controls. I was thinking about just ripping the Oven parts out of 2 stoves and then seperately. That way I can only use 2 when I have little parts and both when I have Big parts.
I will be running the Elements 2 on each side. Also is it imperitive that I use a FAN or would Air slits at the bottom and top be ok. Also where would be the best location for the Temp Sensors? middle/top/ back/ side?
I need to cut up the cabinets next weekend and start melding them together. I just need something big enough to do M/C frames so I can make some good $$$$
Old 05-02-2005, 09:39 PM
customandsound
Guest
Posts: n/a
just get a 150000 btu torpedo heater that is what i use...
Some newbie questions... kiwijetpilot Anodizing Questions 16 03-12-2005 08:18 PM
Wiring 101 :) hvac36 Powder Coating Questions 3 12-23-2004 03:58 PM
A few newbe questions thestormfamily Electroplating Questions 4 06-30-2004 08:54 AM
Powder coating oven suggestion (wiring) tomg552001 Oven Building Forum 1 04-22-2004 01:02 PM
