Old 05-19-2005, 02:29 PM
kchotboat
Default curing with propane heater
Has any one used a Infrared propane heater to cure powder? I need to do some bike frames and they are to large for my oven.
Old 05-19-2005, 04:48 PM
Millermatic
I bought a propane lamp from another P/C website for around $300. I've used it for the last year or so and it works great. My Raytec MT-4 cuts out at 500 degrees, and the lamp will heat up to that temp quickly if its too close to the substrate. I've done 2 motorcycle frames and both turned out flawless. You just have to remain patient and move the lamp around to cure the whole thing.
Old 11-09-2007, 03:14 AM
gomer950 is on a distinguished road
Default Re: curing with propane heater
i'v been looking at propane tank mounted ir heaters. what btu rating is needed, and what kinds of insulation (or other material) do you use to contain some of the heat? i need a shop heater anyway, with this kind of heater i can do both with one heater.
Old 11-09-2007, 06:21 AM
x1rider is on a distinguished road
I'm new to all this as well and trying to design an oven for curing using an IR propane heater.
I used the calculator here to determine the BTU needed for the size of my oven:
http://www.heatershop.com/btu_calculator.htm
I bought my IR heater here:
http://www.northerntool.com/webapp/w...2707_200332707
And I'm looking at this insulation here (1") (9356K11):
http://www.mcmaster.com/
If someone out there thinks I'm totally lost, please let me know!
Old 11-09-2007, 10:55 AM
bradnailer is on a distinguished road
When using a propane heater, do you have to worry about ventilation because of the propane being burned?
oven build/ elec IR/ or propane IR? Carcher7878 Oven Building Forum 8 04-06-2007 04:29 PM
advice on oven propane or electric RCC Powder Coating Questions 13 11-26-2006 09:57 PM
What's a good curing BTU? Heavykote Powder Coating Questions 2 08-01-2005 11:13 PM
powder coating near propane heater? randygrapes218 Powder Coating Questions 3 12-16-2004 09:05 AM
Curing powder coat tomg552001 Powder Coating Questions 17 05-18-2004 05:57 PM
