Guns...are all hobby guns about the same? They're all basically in the same price range. I've read ad's from semi-pro guns blasting hobby guns for 16kv power supplies, but no one seems to have any complaints.
Are there any guidelines on how much surface area a given amount of powder should coat? Thanx. Post edited due to violation of the Terms of Use http://www.caswellplating.com/bbs/viewtopic.php?t=1482 customandsound |
I own and operate a powder coating shop, I will tell you if you get good with the hobby guns from any of the companys you described it will be hard to tell the difference from a part that was sprayed and coated with a pro gun. The only complaint I ever had is they are broken very easly, and the thickness varies more often since you really have to judge by eye how thick your applying it, with a pro gun you can dial that in.
the hobby gun are the work horse of many a pc'er bro even the pc shops usually have a couple around for the smaller jobs that dont require a lot of powder. i would choose the caswell gun also as they have very good support and service. also on the powder most will cover at a rate of 10-15 sq. ft. per pound. you can get more out of it but the coating will be thin. just my 2 cents(or is it 2 sense)
best of luck bro
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
I use three different guns, three different companys, two of them work almost the same and the third I use in special applications because the other two dont seem to do the job, but for the most part I do most of my work with the caswell gun and use the other for back up.
Pro-Tech Powder Coating 93976 Ocean Way 541-247-8168 protech@harborside.com Gold Beach,Oregon |
| Newbie and oven temperature ? | Netnut | Powder Coating Questions | 2 | 05-26-2005 09:49 PM |
| Another newbie - surface area to anodizing time? | kumaichi | Anodizing Questions | 9 | 11-07-2004 03:46 PM |
| I'm a newbie with some questions | acidrain | Anodizing Questions | 5 | 09-18-2004 05:24 PM |
| newbie looking for advice | badboy71499 | Metal Polishing Questions | 1 | 03-03-2004 01:06 AM |
| Newbie questions about Powder Coating | thirdlife | Powder Coating Questions | 3 | 12-16-2003 05:09 PM |
