+ Reply to Thread
Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 22
Thread: Has anyone Powdercoated Magnesium?
  1. Join Date
    Mar 2005
    Posts
    64
    I have some motorcycle parts to do that are magnesium. What are the characteristics of this metal?
    I think it's a softer metal and therefore the outgassing process might breakdown the metal.
    If anyone knows, what temp would be optimum for curing?
    Share with Facebook
  2. Join Date
    Apr 2004
    Location
    Burton, Michigan
    Posts
    108
    Be very very careful when working with magnesium. It is a flamable metal and will burn very hot!! I don't think that the temps needed to cure PC will make it burn, but if you are sanding or grinding it, the dust is easily ignited. I've heard of people getting badly burned from it. As for PCing it, Noob2PC PC'd a set of Cadillac magnesium valve covers. I believe that he had a lot of outgassing problems with it though. I'm sure he'll chime in as soon as he sees this. Good luck and be safe!!
    Kris
    Share with Facebook
  3. I've done 2 magnesium engine parts off a Yamaha yz250f. I just pre-baked and coated as usual...no problems and the parts came out great.
    Share with Facebook
  4. Join Date
    Jan 2004
    Location
    Beaufort, SC
    Posts
    121
    I have powder coated a set valve covers that were mag.
    I bought a black powder the was out gas free and it did work. It was used as a base coat under a mirror red. I did try one of the valve covers without this powder and it turned ugly as you know what from it out gassing so bad. So i do know this stuff does work at least 99% out gas free.
    Post edited due to violation of the Terms of Use
    http://www.caswellplating.com/bbs/viewtopic.php?t=1482
    customandsound
    Caswell Sell powder so please keep the marking to them.. There is no selling of other powder on the board Please read the link...
    Warning
    Share with Facebook
  5. Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    315
    Quote Originally Posted by remotestartdepot
    Kris
    THINGIE!!!!!!!!!!!!! RUN!!!!!!!!!!!!!!!!!!!
    Yeah a lot of Out Gassing, I prebaked at least 4 times and still got bubbles. If you look in the album for my pics you will see what they look like. At the Curing Temps there is no danger of fire. It is the Dust and particles from sanding that ignite first. be sure to sand in a very well ventalated area, if you have a fan use that to creat good airflow away from the part.
    I know someone who did manage to light some on fire, he dropped it in a bucket of water and it flared up. It burns so hot it vaporizes the water around the peice and then uses the O2 from the water. You will have to use a Foam or Sand to put out a Mag fire. Kris, it was MTA.
    Share with Facebook
  6. Join Date
    Mar 2005
    Posts
    64
    Thanks for the answers to myquestions! I was planning on sandblasting it with either glass bead or coal slag. DO you thing that would be a problem?
    Share with Facebook
  7. Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    315
    Quote Originally Posted by Heavykote
    I used Alum Oxide then finished up with a Drill powered wire wheel.
    Share with Facebook
  8. Join Date
    Nov 2004
    Posts
    75
    how do you tell the difference between magnesium and aluminum. Sometimes it looks the same. Thanks
    Share with Facebook
  9. Join Date
    Apr 2004
    Location
    Burton, Michigan
    Posts
    108
    [quote="Noob2PC You will have to use a Foam or Sand to put out a Mag fire. Kris, it was MTA.[/quote]
    OK, now I remember it being him. Didn't he get a bunch of dust on his shirt and burst into flames from a grinding spark? I vaugely remember the incident.
    Share with Facebook
  10. Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    315
    Quote Originally Posted by Noob2PC
    Yeah, that is what happened.
    Share with Facebook
+ Reply to Thread
Page 1 of 3
1 2 3 LastLast
Thread Information
Users Browsing this Thread
  1. Coloring/finishing Magnesium Bronze
    By homydog in forum Other Metal Finishing Questions
    Last Post: 04-03-2005, 03:03 AM
  2. Polishing Magnesium
    By etyrrany in forum Metal Polishing Questions
    Last Post: 11-14-2003, 09:57 AM
  3. Can you coat magnesium?
    By tomg552001 in forum Powder Coating Questions
    Last Post: 09-04-2003, 12:23 AM
  4. Magnesium plating
    By thelasershop in forum Electroplating Questions
    Last Post: 04-04-2003, 11:12 PM
  5. magnesium?
    By excess enemy in forum Electroplating Questions
    Last Post: 12-04-2002, 09:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
