Looking to do some powder on my scooter. Need to build a simple oven probally 2ft square. Would like to try to keep the heat source as simple as possible and still get good results. My thoughts are to buy a counter top gass grill and build a box out of cement backboard that sits on legs right at the top of the grill so I can still adjust the grill temps. Or hit the thrift store for a couple of toaster ovens and wire something up.
Thanks Chris |
Below is a link for a guy that made an ext for his household oven. I did the same before I built my 8" oven, & it cost me about $30.00 & a half hour of work. It does work! Scroll down about 2/3 the way down.
Good Luck Bob http://web.archive.org/web/200202140..._equipment.htm
www.capecodpowdercoating.com |
that box there is 24" deep 40" tall 26" wide the only problem i have had is i got the box cherry red on the back side a few times. there is no fiberglass in it either it is straight metal..
if you adjust the intake tube you can keep the heat to 400/450 no problem. i built it just to do wheels in.. i have had it at 700 for an hour for ceramic but i would not do much of it in there.. i got 3 ovens the biggest being 8'x8'x8' i run 2 200k heaters in it i got another oven 24'long 18'wide and 8' high i need to run some elemnts in it it will be electric and gas .. the gas will get it to the temp i need then the electric will kick in and keep it there... well back to powdering i go .. i got part's in the oven as we speak |
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 03:43 PM |
| advice on oven propane or electric | RCC | Powder Coating Questions | 13 | 11-26-2006 09:57 PM |
| Oven problem !!!!! | tavo1765 | Powder Coating Questions | 7 | 10-06-2005 05:21 PM |
| Newbie and oven temperature ? | Netnut | Powder Coating Questions | 2 | 05-26-2005 09:49 PM |
