Specifically, I'm wondering if I should worry about PC'ing the inside of certain engine components. I have a lot of cooling system parts that are very pitted out inside (it is a 56 year old truck), and I'll certaintly PC the exterior, but I wasn't sure if any PC on the inside would stand up to antifreeze flowing through there.
I'd hate to have the PC break down and damage something once it's all put together, but if PC is tough enough to stand some antifreeze, then I'd be able to stop the pitting, or at least slow it down.
Anyone ever done an interior coolant passage? Did it work? If you can't PC the inside, does anyone happen to know of a product that would seal the interior against the antifreze?
Dan
LinkBack URL
About LinkBacks
