+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 15
Thread: info on blast media
  1. #1
    Join Date
    Mar 2004
    Location
    Gold Beach, Oregon
    Posts
    322
    Default info on blast media
    hope this will help a bit on the diff stuff that can be used..
    Blast Media Walnut Shells
    Use this abrasive to clean internal parts; any of the soft abrasive material left in the working part with break down with minimal damage. Great for gentle paint and carbon removal from ferrous metals. For use at 80 psi max. Be sure to wear appropriate respiratory protection.
    Blast Media Silicon Carbide
    Silicon carbide has very sharp edges which make it ideal for removing heavy rust, welding and brazing prep, and for glass etching. 60 grit size. Use at 80-90 psi max. Be to sure to wear an appropriate respirator.
    Blast Media Poly Bead
    Gentle Poly Abrasive will not harm fragile surfaces and produces less dust. Excellent for stripping paint or powder coating from sheet metal and fiberglass Use at 35-90 psi max. Be sure to wear appropriate respiratory protection.
    Blast Media Glass Bead
    An all-purpose abrasive for all types of metals and many plastics. Best on softer metals like aluminum and brass. Great for cleaning pistons, engine blocks, and light rust removal with minimal dust. Meets mil spec MIL G9954A for size uniformity and is 70-100 grit size. Use at 60 psi max. Be sure to wear appropriate respiratory protection.
    Aluminum Shot Media - Lasts up to 1000 times longer than glass bead or aluminum oxide.
    Exotic low dust, air cast aluminum shot media cleans without removing casting details. Effectively cleans without embedding or leaving ferrous contamination. Ideal for aluminum castings, radiator tanks, and other parts where a unique sheen is desired.
    Pro-Tech Powder Coating
    93976 Ocean Way
    541-247-8168
    protech@harborside.com
    Gold Beach,Oregon
    Share with Facebook
  2. #2
    customandsound Guest
    Remember the higher the grit the rougher the surface you have and you dont need no more than a enought for the powder to bite on and stay
    Share with Facebook
  3. #3
    Join Date
    Apr 2007
    Posts
    143
    Default Re: info on blast media
    would it be conclusive enough to say that glass beads on some soft aluminum have been known to get embedded in aluminum?
    Share with Facebook
  4. #4
    Quote Originally Posted by FiReBReTHa
    Yes, you are correct.
    Share with Facebook
  5. #5
    Join Date
    Dec 2006
    Posts
    760
    Yup, if you have to use it, keep the psi at the min. needed to remove material and blast at an angle not straight at the part.
    Share with Facebook
  6. #6
    Join Date
    Apr 2007
    Posts
    262
    so use alluminum oxide on alluminum ?
    Share with Facebook
  7. #7
    Join Date
    Dec 2006
    Posts
    760
    Quote Originally Posted by donafams
    Yes, it's better than glass bead for aluminum. Always blast at angle.
    Share with Facebook
  8. #8
    Join Date
    Sep 2003
    Location
    Rio Rancho, NM
    Posts
    533
    I always prefer to hit AL with scotch-brite pads with a die grinder or if the piece is large use a larger grinder & pad.
    SouthWest Powderworx
    Tyler Nutter
    5054803934
    www.swpowder.com
    myspace/swpowder
    tyler@swpowder.com
    Share with Facebook
  9. #9
    Join Date
    Mar 2010
    Location
    Hot Springs, AR
    Posts
    6
    Quote Originally Posted by Blademan View Post
    There is another form of Media used , Novacite. It has the Mohs hardness of 7 and is very friable. It will not leave the dents that you are talking about in the aluminum. Check it out.
    Share with Facebook
  10. #10
    Good info there Blademan. I never knew the media had to be sprayed at such low PSI. I have my glass bead in my blast cabinet cranked past 100 psi. Guess that explains why it breaks down so fast! hahahaha! Anyone ever use Black Beauty? Also, I always thought Aluminum oxide tears the heck out of softer metals such as aluminum. Should I perhaps run aluminum oxide in my cabinet?
    Share with Facebook
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Thread Information
Users Browsing this Thread
  1. where to buy blast media?
    By joenintiesc in forum Other Metal Finishing Questions
    Last Post: 03-16-2010, 06:38 PM
  2. Which Sandblasting media
    By Mick40 in forum Powder Coating Questions
    Last Post: 04-18-2006, 11:57 PM
  3. Anyone with experience on tumblers or the media to use?
    By krsimulis in forum Metal Polishing Questions
    Last Post: 06-02-2004, 01:18 AM
  4. What type of media to use?
    By Tito in forum Other Metal Finishing Questions
    Last Post: 05-27-2004, 08:10 PM
  5. Blast Media info
    By Bud in forum Powder Coating Questions
    Last Post: 05-05-2004, 10:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
