i built my oven 3x3x6ft tall, my first attempt to heat it was using a 150,000btu torpedo style heater, it got to 500 in like 4 min. but it is extremely difficult to keep the temp. where i want it. so my question is how many regular electric elements would i need to maintain 400deg. if i preheated the oven with the torpedo? assuming that it is insulated well.
![]() No problems at all .. heats to 400f in under 10 miuntes .. the out put of a 150k heater is 2400f. so you will be good up to a 6x6 box then you will need to add a bigger heater... Cost of running that heater is peenies per job compare to the big electric bills |
That's an interesting way to build an oven. Two questions: How come the blast from the heater doesn't blow the powder off the part, and is there an outlet somewhere on the other side of the oven?
I have a 75,000 BTU heater I could try. Outdoors, though |
there is not exhaust on that box.. the powder has never been blown off any part .. But if you want you can put a deflector in it.. to push the force air to the bottom..
that box has not fiber in it it is straight metal. It is used indoors when i do fire it up i open the doors.but that was in my hobby.. in the shop it is all vent to the outside and in the winter that is my only heat while i am at the shop i leave for the night i turn the heater( the main ) on and it is set at 60f.. |
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 04:43 PM |
| advice on oven propane or electric | RCC | Powder Coating Questions | 13 | 11-26-2006 10:57 PM |
| Pics of Electric Oven Construction | viper56 | Powder Coating Questions | 19 | 02-12-2006 08:37 PM |
| DIY electric oven question | LeeParsons | Powder Coating Questions | 1 | 07-04-2005 10:09 AM |
| Electric Oven Construction Plans | viper56 | Oven Building Forum | 8 | 08-03-2004 11:20 PM |
