Old 07-10-2005, 08:48 PM
Heavykote
Default Having a go at powdercoating plastic...pics
Yes guys I've decided to give plastic a try. First job, CENTERCAPS! Plastic center w/aluminum trim ring around.
Here's a pic of one with chrome powder:
Here's one I started to sandblast:
I don't have any pics with the results, but I can tell you that 400 degrees for 10 minutes doesn't work with this type of plastic.
It appears that after trying 400, 300, and 250 the 250-300 range is best. The only thing I didn't do till my last 2 caps was to heat up the adhesive under the logo,
then prying it off.
Old 07-10-2005, 11:09 PM
customandsound
Guest
Posts: n/a
i am going to do my centers. can you post a pic of the final result
Old 07-11-2005, 04:19 PM
Heavykote
Definitely, but today the temps are in the 90's so I'm CHILLIN OUT!
Old 07-11-2005, 05:13 PM
customandsound
Guest
Posts: n/a
that is why i hung out in the house all day .... i am waiting til 9 or 10 to go out and powder.
Heavykote can you pm me your domain link.. i tryed to fid you car on ther to take a peek
Old 07-12-2005, 09:26 PM
Heavykote
Okay, the deed is done. I ended up putting the centercap in at I think 263+ or - . Stripping the center of the cap down was a major pain, but near the end I found a easier way to do it.
The aluminum ring came out good,BUT the center plastic piece became bubbly. This I think is mostly cause of the temp and time in the oven. I think 5 to 10 miuntes is top for a piece. I was actually smoking some ribs on my day off while doing this. Big mistake, but I wasn't thinking clearly especially while drinking a couple of beers. Funny thing is the only time I drink is when I grill.
I guess my next test will be when I get more centercaps, but progress was made...
Old 07-12-2005, 11:04 PM
customandsound
Guest
Posts: n/a
they look better than i thought they would... i got flat centers for my aucra i want to color match the wheels either that i am just going to use chrome lug's
Old 07-13-2005, 08:44 PM
Heavykote
I know they can be done right! I just have so much to do and so little time in a day. Right now I'm about to do a translucent red impala rim. I'll post pics when I'm done...
  #8 (permalink)
Old 07-13-2005, 08:48 PM
customandsound
Guest
Posts: n/a
they can be done i have seen a few flat ones done in a low cure .. i am going to color match mine charcoal met. i got to get the livestock taken care of first so i can get time for my own projects
powdercoating plastic engine pieces myillwillinc Powder Coating Questions 10 04-08-2005 05:58 PM
cheap powdercoating heater/chrome power supply question dagobert Electroplating Questions 0 06-01-2004 11:59 AM
Powdercoating plastic mystrwizard Powder Coating Questions 11 04-23-2004 07:38 AM
Plating clear plastic Dinosaurius Electroplating Questions 2 06-11-2003 12:06 PM
copper peeling from plastic chromeman66 Electroplating Questions 1 02-06-2003 01:35 PM
