FREE POWDER COATING SYSTEM
I need an expert advice. A friend of mine (after seeing my TB spacer) asked if I can powder coat an aluminum propeller from his boat? Without thinking replied ofcourse!
After looking at, I don't see any sealer, bearing, plastic or rubber in it, so far so good! I have to strip the black (non marine) paint, prepare the surface, coat and bake, right? He wants it shiny black, so my question is: what caswell black is good for marine application, or do I use clear after black is applied Thanks for your time frank |
I do a ton of items that go into the ocean. ALL ocean applications need a "Zinc Rich Primer". This is a powder primer. After proper prep, you shoot the item with the primer, put it in the oven for ONLY roughly 3 minutes (until the primer gels). Remove from oven & let cool to roughly 140F & then shoot the top color & cure as directed for the top color. Good Luck Bob
www.capecodpowdercoating.com |
that is right up your alley bob...
But the magic black and clear to add depth to the powder is your best bet. unless you use a mirror black with a 500+ clear.. like these: ![]() i try to clear as much as i can if the customer is willing to pay a few more buck's it look's alot better and the clear will help on the micro scratches that will show on the darker color |
I am almost 100% sure all aluminum props have a rubber insert between the hub and blades. I know stainless props come in both solid hubs and non. You should check with the company the made the prop.
We talked to the boat rebuilder, and he assured us there is NO rubber itside! So I went ahead, stripped, preheated, coated and here is the finish product:
http://www.caswellplating.com/bbs/al...php?pic_id=590 but I am not soooo happy about it http://www.caswellplating.com/bbs/al...php?pic_id=592 Can you tell me why is it foggy ![]() Maybe in those areas the clear coat is thicker? The owner was happy, didn't say nothing yet, it was free for him. Should I strip it and re-coat? After you take the part out of the oven, how soon you see orange peel, or yellowis discolorisation? frank |
Hey Netnut. It's tough to tell by just looking at the picture but I wonder if you have a condition called blooming. I'm not completely sure what causes it(something in the manufacturing process of the powder) but I've seen it in candies and clears. Basically the part developes an inconsistant almost blotchy haze. Almost looks like frost, but has no texture to it. Well if that's it, the only way to get rid of it is by reshooting the part.
| Marine Grade Sealer | reelpeeler | Anodizing Questions | 3 | 04-06-2005 09:11 PM |
| Hot powder application? | Hemi-T | Powder Coating Questions | 2 | 12-09-2003 10:13 PM |
| plug n plate application thickness | mikey10 | Electroplating Questions | 0 | 10-24-2003 11:19 PM |
| Marine tools | boatman | Electroplating Questions | 2 | 12-10-2002 08:57 AM |
